New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Jun 14, 2024 at 6:15 PM
    #6761
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    Whos the alignment guy? Im puttting these in and doing a bunch of other stuff for the lower arms
    CTSpruceMica likes this.
  2. Jun 14, 2024 at 6:56 PM
    #6762
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I know that drew has a guy to mount and align big tires.....what are you putting on?
  3. Jun 15, 2024 at 5:08 PM
    #6763
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    CTSpruceMica and Chasespeed like this.
  4. Jun 15, 2024 at 6:43 PM
    #6764
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I have a set of worn out lowers sitting at my parents from Jason @Bruce988jl . I run factory eccentrics and total choas cam tab gussets without issues. Could also do the line of weld on the tab as an even cheaper option
    Bruce988jl and CTSpruceMica like this.
  5. Jun 15, 2024 at 6:46 PM
    #6765
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Already ordered the cam tabs and hardware. I made the mistake of throwing out factory hardware when it was rusted on to the lca. This solves that with grade 8 hardware
  6. Jun 15, 2024 at 7:10 PM
    #6766
    tacobell007
    Drew
    Western MA
    I mean you could do anti-seeze or wheel bearing grease to keep it from seezing. Up to you though, not sure what hardware goes for these days since I did mine in 2019
  7. Jun 15, 2024 at 8:37 PM
    #6767
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Zaks auto in Hudson did mine and John's alignment, ask for Tyler
    CTSpruceMica and tacobell007 like this.
  8. Jun 15, 2024 at 8:54 PM
    #6768
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Tyler’s out on injury til like august :( I just talked to them the last couple days
  9. Jun 15, 2024 at 9:14 PM
    #6769
    Brownmatthall
    2016 TRD OR DCSB
    Womp
  10. Jun 16, 2024 at 7:31 AM
    #6770
    Merling
    James
    NH
    I was thinking I was gonna go skinny 33s but they’re like 60 lbs a piece. That’s like 33% more weight than what I have now. Anyone have some insight on what to expect if I did?
    Another option in my mind is to go with toyo a/t III’s which are about 40 lbs a piece but in the 265/75R16 size. Just not sure if the juice is worth the squeeze for 3/4” or so
    Chasespeed likes this.
  11. Jun 16, 2024 at 7:44 AM
    #6771
    Brownmatthall
    2016 TRD OR DCSB
    What tire are you looking at that's 60# for a 33? My 35s are 66/67, that's an absurd weight lol. I ran skinny falken MTs before and those were 55# I believe, they worked really well and didn't hit the mpg's terribly. But if you're not really wheeling stuff where those incremental gains make a difference I wouldn't
    tacobell007 likes this.
  12. Jun 16, 2024 at 8:56 AM
    #6772
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    lol when you do your lower bushings I may need help with mine, I haven’t gotten around to it yet.
    I run skinny AT3Ws and I think they are 56# a piece. Honestly they run great, no overall complaints. You do lose a little bit of MPG, but not as much as I expected which is good.
  13. Jun 16, 2024 at 9:07 AM
    #6773
    tacobell007
    Drew
    Western MA
    I think my general grabber at in 33x12.5x17 were 60ish pounds each
  14. Jun 16, 2024 at 10:49 AM
    #6774
    crashngiggles
    Jared
    So yes, 60#'s a piece will most certainly be a possible issue for you if not regeared. Mine are 285's and my toyo AT3'S (which I highly recommend btw) are only 55lbs a tire. One of the o lyrics reasons why I tried the toyos over the falkens (which are still a great tire) but the falkens are much heavier for the same size tire. Also keep in mind that you will need to balance the weight vs the load rating as well with what you plan on doing with the tires. A SL load rating are going to be lighter and more comfortable but not as rated for heavy trails. E rated are stiffer and heavier but can take a lot of trail damage. C rated is a great sweet spot.
  15. Jun 16, 2024 at 11:55 AM
    #6775
    Brownmatthall
    2016 TRD OR DCSB
    I noticed the skinny tires seem to be comparable in weight, if not ever so slightly more than the wider counterparts in the same size a lot of the time. Rolling resistance plays a little bit in it as well but I don't think I'd run a skinny again. Toyos are on the lighter end of the spectrum I think, falken and the grabber are definitely on the heavier side
    crashngiggles and tacobell007 like this.
  16. Jun 16, 2024 at 4:02 PM
    #6776
    Merling
    James
    NH
    Wildpeak AT4Ws, apparently. Seems crazy to me lol. But I liked that they're ATs, which should help a bit with noise
  17. Jun 16, 2024 at 5:16 PM
    #6777
    tacobell007
    Drew
    Western MA
    The biggest issue I found is physics of diameter. Rotational forces are A LOT bigger of a player than tire weight. Going from the general grabbers to my Mastercraft mxt's those were only a 1lb difference but the rotational force difference from 33s to 35s is what gets you
  18. Jun 17, 2024 at 2:25 AM
    #6778
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    This you?
    tacobell007[QUOTED] likes this.
  19. Jun 17, 2024 at 2:36 AM
    #6779
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I have a set of OEM TRD OR wheels, wrapped in 265/75-16 Goodyear UltraTerrains(and a steel spare with 265 Falken) if you want to give them a whirl?
    crashngiggles likes this.
  20. Jun 17, 2024 at 2:56 AM
    #6780
    tacobell007
    Drew
    Western MA
    I wasn't quite at that level of math yet, close though
    CTSpruceMica[QUOTED] likes this.
