New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Sep 10, 2024 at 4:39 AM
    #7801
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Yeah I was going to buy the manifold off the guy in that thread that was asking about it. I showed it to Lou’s and a picture of the manifold. He told me if I wanted to take a chance and buy it he would put it on but it looks just like the one he already tried. So if it doesn’t fit he would have to charge me the labor to take mine off and to put it back on. Someone else ended up buying it.
  2. Sep 10, 2024 at 4:40 AM
    #7802
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    Its definitely a much stronger way to go about it then stock or anything else I've seen. Personally I am not a fan of C4's bolt in setup.
    I could cut the parts out for you or do the whole shebang. Either way works fine for me.
  3. Sep 10, 2024 at 5:24 AM
    #7803
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    I have to use washers between my bolt and skid to keep the threads from passing through on mine
  4. Sep 10, 2024 at 5:31 AM
    #7804
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  5. Sep 10, 2024 at 5:33 AM
    #7805
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    @Brownmatthall You can try and sell off your hitch from my place if you want. I can dispose of whats left of the bumper and put up some pics
  6. Sep 10, 2024 at 5:39 AM
    #7806
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Greatly appreciated, send the pics my way when you do!
    AllTacosFloat[OP] likes this.
  7. Sep 10, 2024 at 5:40 AM
    #7807
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Sounds good, itll probably be next week. I want to try to get my bumper on before the weekend
    Brownmatthall[QUOTED] likes this.
  8. Sep 10, 2024 at 5:43 AM
    #7808
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Also torque down all the bolts to 80 ft lbs if you use antiusieze/loctide and 110 if you dont.
  9. Sep 10, 2024 at 5:53 AM
    #7809
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Truck in question is actually a 2010 with facelift!
    Going to look at it asap
  10. Sep 10, 2024 at 2:39 PM
    #7810
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Sir @m603holden I would like to know if you are available this Saturday early afternoon to meet up. I would like to get that exhaust.
  11. Sep 10, 2024 at 4:51 PM
    #7811
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    We can criss that bridge when it's time.
  12. Sep 11, 2024 at 4:56 AM
    #7812
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    @CttAznRanger How did you get the LBJ's out?. I decided to try to press them out while the bumper was cooling off and literally exploded part of my BJ press.
    I am making something today to help press it out
  13. Sep 11, 2024 at 4:59 AM
    #7813
    AllTacosFloat
    Boston ish
    I think @tacobell007 has done this
  14. Sep 11, 2024 at 6:12 AM
    #7814
    CttAznRanger
    Brandon
    Boston, MA
    Just took the OEM jack, a 4x4 block of wood and a torch. Place the OEM jack on the 4x4 between the bushings, and crank it up till they touch. Heat the ever living shit out of the side you’re trying to push out (as evenly as possible, but not needed to the point where the paint starts to come off), then slowly crank it. Ideally use a long ass wrench on the jack and not the OEM handle to turn it. Go at it slow and it should just start sliding out.
    I did end up starting a few rubber fires, but it came out easy.
  15. Sep 11, 2024 at 6:12 AM
    #7815
    CttAznRanger
    Brandon
    Boston, MA
    @TacoTuesday603 Worst case scenario I can always get them out for you.
  16. Sep 11, 2024 at 6:14 AM
    #7816
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    I didnt try those yet, talking about the ball joint. Have the clip off and tried pressing using my 20 ton. There isnt enough flat space on the bottom to support the arm
  17. Sep 11, 2024 at 6:33 AM
    #7817
    CttAznRanger
    Brandon
    Boston, MA
    OH! I have a ball joint press kit from Powerbuilt, lol.
  18. Sep 11, 2024 at 7:34 AM
    #7818
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Yeah my problem is there is like basically no room on the backside. I am building a dodad today to help.
  19. Sep 11, 2024 at 11:13 AM
    #7819
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
  20. Sep 11, 2024 at 1:00 PM
    #7820
    CttAznRanger
    Brandon
    Boston, MA
    I'm gonna be up in the Rockingham mall area Saturday afternoon to pick up my exhaust. Wanna meet up to get my press kit?
