New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Sep 15, 2024 at 9:58 AM
    #7861
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
  2. Sep 15, 2024 at 1:08 PM
    #7862
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Had a mini mod day with Brandon @CttAznRanger today. Got to try out the wall mount.....I mean hand truck mounted spring compressor. Took a couple of minutes to get used to but after using that thing you NEVER want to go back to those "rinky dink" store bought ones. Had to take a wire wheel to the shock body threads because we couldn't turn the collar. Then we found that the bearings for their lower shock bolts were so bad they were almost too dangerous to drive on.
    Yeah, you see that gap above the spherical bearing? That's not supposed to be there lol
  3. Sep 15, 2024 at 1:40 PM
    #7863
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    So, in trying to replace the spherical bearing, I was able to pop it out (without the outer sleeve) and look at this… the bearing wore through the sleeve and into the shock itself… I guess these Kings are going to be shelved for a bit until I get someone to rebuild them…
  4. Sep 15, 2024 at 1:51 PM
    #7864
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    What's it looking like cleaned up?
  5. Sep 15, 2024 at 1:53 PM
    #7865
    m603holden
    Marteeen
    New England
    Kartek part numbers if you need them.
  6. Sep 15, 2024 at 1:53 PM
    #7866
    CttAznRanger
    Brandon
    Boston, MA
    That’s as clean as I got it. It’s rubbed to the point where the bearing has made its way into the shock. There’s a gap under the screwdriver, and the screwdriver should be flat where the bearing should be pressed in.
  7. Sep 15, 2024 at 1:54 PM
    #7867
    CttAznRanger
    Brandon
    Boston, MA
    I have the bearings already, but it’s the hole in the shock that’s worn in.
  8. Sep 15, 2024 at 1:57 PM
    #7868
    m603holden
    Marteeen
    New England
    Oh bummer. Got the part # for the eyelet ?
  9. Sep 15, 2024 at 2:38 PM
    #7869
    CttAznRanger
    Brandon
    Boston, MA
    Negative, will probably need to rebuild the whole thing
  10. Sep 15, 2024 at 3:08 PM
    #7870
    CttAznRanger
    Brandon
    Boston, MA
    @m603holden who or what company was in PA that does the shock rebuilds? I might give them a call to see if I can drop all 4 corners off to them for a rebuild.
    AShive92 likes this.
  11. Sep 16, 2024 at 2:13 AM
    #7871
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    I believe thats @AShive92
  12. Sep 16, 2024 at 4:33 AM
    #7872
    CttAznRanger
    Brandon
    Boston, MA
    Ty on that. I’ve sent some messages around. Hoping to hear back asap.
    AShive92 and Toolndie7[QUOTED] like this.
  13. Sep 16, 2024 at 6:25 AM
    #7873
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Nice to hear that it’s useful.
  14. Sep 16, 2024 at 7:07 AM
    #7874
    crashngiggles
    Jared
    I really can't thank you enough sir. It's a game changer.
  15. Sep 16, 2024 at 10:50 AM
    #7875
    AShive92
    AShive92 Well-Known Member
    Andrew
  16. Sep 16, 2024 at 2:06 PM
    #7876
    InfernoAlt
    InfernoAlt Well-Known Member
    Any off road trips coming up after the AOAA invasion Columbus Day weekend?
    AllTacosFloat[OP] likes this.
  17. Sep 16, 2024 at 2:55 PM
    #7877
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Nothing planned but I’m down. Anywhere you’re hoping to go?
  18. Sep 16, 2024 at 3:07 PM
    #7878
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
  19. Sep 16, 2024 at 3:37 PM
    #7879
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Woodstock VT two weekends after AOAA :spy:
  20. Sep 16, 2024 at 3:59 PM
    #7880
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    This then 3 bears in November?
