New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Nov 10, 2024 at 5:43 AM
    #8701
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    For toys for tots? I most likely will be there to set up around 8am but 9am is usually the time we start since that is the time that Runnings opens.
  2. Nov 10, 2024 at 6:01 AM
    #8702
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Just figuring out what time I need to leave the house.
    crashngiggles[QUOTED] likes this.
  3. Nov 10, 2024 at 6:57 AM
    #8703
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    I have a feeling I won’t have anymore alignment issues
  4. Nov 10, 2024 at 7:02 AM
    #8704
    AllTacosFloat
    AllTacosFloat [OP] If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    I use a pipe wrench… works first try every time.
    But yeah, it doesn’t look that bad at all. Certainly worth a try.
    :curls: Beefy
    I’m pulling my taco tabs in favor of those. They fit better in the cam tab opening
    hyrule_trd and GarlicFarts like this.
  5. Nov 10, 2024 at 8:22 AM
    #8705
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Until you bend the tab, definitely wouldn't know anything about that though :anonymous:
  6. Nov 10, 2024 at 9:33 AM
    #8706
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    I had to straighten all the tabs.. they were bad. Basically if I have a bad alignment it’s either spc slipping, bent tie rod, or bent frame
  7. Nov 10, 2024 at 9:34 AM
    #8707
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Yep they fit great. After paint probably .030” of movement. Impressive for plasmacut parts
  8. Nov 10, 2024 at 3:32 PM
    #8708
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Super late to this. I'm glad you were able to put it to use. I triple checked that I had all the parts, but I was praying I didn't miss some stupid little things
    MQQSE and CttAznRanger[QUOTED] like this.
  9. Nov 10, 2024 at 5:02 PM
    #8709
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Don't worry, it was all there, but I somehow dropped one of the gaskets while installing it. Ended up with a leak and a CEL, then went to get an OEM gasket, which also didn't seal it up right, so I ended up sealing the flange with some high temp JB Weld...
    MQQSE likes this.
  10. Nov 11, 2024 at 1:21 PM
    #8710
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    All done and aligned decently
    MQQSE, Roody, BostonBaja and 8 others like this.
  11. Nov 12, 2024 at 10:23 AM
    #8711
    m603holden
    Marteeen
    New England
    Lol your hydrolic fittings look a little better than mine on those foxs
    MQQSE likes this.
  12. Nov 12, 2024 at 10:25 AM
    #8712
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
  13. Nov 12, 2024 at 11:06 AM
    #8713
    m603holden
    Marteeen
    New England
  14. Nov 12, 2024 at 1:39 PM
    #8714
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  15. Nov 12, 2024 at 2:08 PM
    #8715
    crashngiggles
    Jared
    Lol.....not anymore since i have that wall....I mean "Hand truck" mounted one ....lol
  16. Nov 12, 2024 at 4:06 PM
    #8716
    AllTacosFloat
    Boston ish
    Stuck pulling a generator all day, think there was some blow by:rofl:
    IMG_3494.jpg What you can’t see in the dark is worse, this was the pic for my boss to retire the thing.
    Now fixing up an old one to take its place. Till then we are one truck down.
    Brownmatthall and MQQSE like this.
  17. Nov 13, 2024 at 6:39 AM
    #8717
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
  18. Nov 13, 2024 at 8:07 AM
    #8718
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    It's a morning...
  19. Nov 13, 2024 at 8:11 AM
    #8719
    AllTacosFloat
    Boston ish
    Mine had a hell of a commute. Saw a bobcat… no deer. They must know it’s hunting season.IMG_3503.png
  20. Nov 13, 2024 at 8:16 AM
    #8720
    Chasespeed
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Hahaha, yeah they do... they been hanging out in my yard, and since the water is so low, bouncing between me, and my neighbor across the way....
