New England Mod & Meetup Thread:
Discussion in 'North East' started by AllTacosFloat, Apr 14, 2022.
  1. Mar 10, 2025 at 9:55 AM
    #9601
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Does look like it leveled out, if there is a rake it would be one of those things you notice because you own it but otherwise nobody would notice with a passing glance. Looks good!
  2. Mar 10, 2025 at 12:17 PM
    #9602
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    I am sure you do know that place. Hit the subway for dinner.
    Yeah, it has settled a little. I could deal with a little more but at least the Carolina squatting seems to be gone.
  3. Mar 11, 2025 at 5:04 AM
    #9603
    InCogNeatOh Parts
    InCogNeatOh Parts Well-Known Member
    I am trying to plan my electrical/light set up. I am thinking, cheaper lights for now, but good wiring set up with the ability to upgrade the lights later if needed. maybe some sort of quick connect/disconnect set up.
    I was looking at these lights last night, https://www.amazon.com/dp/B0DGPPWK1H/?coliid=I5FZLCFFZ76VS&colid=OUNVWEF79CGH&th=1
    Is there some way I could switch modes via a rocker switch in the truck? Or wire in some sort of switch near the lights to change their mode?
    CttAznRanger likes this.
  4. Mar 11, 2025 at 5:09 AM
    #9604
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Fox and Locked suspension 63's Skinny 33's
    I think you could do in cab by using 3 switches. 1 latching switch for light power then 2 momentary for swapping modes on to yellow wire one to white wire. Youd need to get one and mess around with it.
  5. Mar 11, 2025 at 5:22 AM
    #9605
    GarlicFarts
    Lil Rhody
    My lights strobe from the switch panel, not the lights. I have regular LED pods.
    Here's the one I have now:
    https://www.amazon.com/dp/B09GFHNN9Z
    If I had to do it again, I'd probably go for this (or similar, this is just the one that I found):
    https://www.amazon.com/dp/B0DTDY2C9...=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM&th=1
    For reasons:
    • RGB, not that I care, mine's blue, I have it turned all the way down, but stil, could be nice and cool :p
    • Brightness controller on the panel itself, I have to have a button that triggers it. I just dedicated one of my switches to momentary to do such a thing, but would be nice to not have that issue. I see some have auto dim, that might solve the same critique.
    • I would PROBABLY go down to 6, instead of 8 - but the extra 2 buttons doesn't take up so much space that it's an issue. Still, would probably go down to 6.
    That said - I highly recommend the one I have now.
  6. Mar 11, 2025 at 5:39 AM
    #9606
    InCogNeatOh Parts
    not a fan of 3 switches, however, I have thought about putting a switch in the back. Goal is have strobe for chase lights, and then switch to flood for rear light when parked. I had been thinking about getting chase and then floods, but I want to try to just use on set of lights versus multiple.
  7. Mar 11, 2025 at 5:44 AM
    #9607
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Idk what other people think but I think strobes for chase lights dont help at all and I find them annoying. Could do a momentary 2 in 1 switch like a window switch.
  8. Mar 11, 2025 at 5:57 AM
    #9608
    InCogNeatOh Parts
    I already have a Aux fuse panel that I will use, money spent along time ago.
  9. Mar 11, 2025 at 6:01 AM
    #9609
    GarlicFarts
    Lil Rhody
    Use red or amber. Red is a BIG BIIIIIIIIG nono on the roads, but for camp lights - red doesn't attract the skeeters. Also, in the cab, red doesn't kill your night vision. My map and dome lights are red because of that. Time to time I wish I had switchbacks, so I am looking at maybe doing that instead.
    I only have them just because. I didn't know the panel could do that when I got it :rofl:
    :thumbsup: makes sense.
    https://www.amazon.com/FXC-Waterpro...42&sprefix=switch+panel+,aps,233&sr=8-10&th=1
    Can look at switch panels like these too. Don't know where the heck it would go.
  10. Mar 11, 2025 at 6:02 AM
    #9610
    GarlicFarts
    Lil Rhody
    :rofl: this came up as a highlight on my google page today.
  11. Mar 11, 2025 at 6:42 AM
    #9611
    InCogNeatOh Parts
    I have red and green inside, both are good for night and don't attract the flying friends. And for some reason I like the green, probably because not as popular currently.
    And that switch panel looks cool, so there for it should be a must.
    I am hoping for a few rocker panels in the dash and be done.
  12. Mar 11, 2025 at 6:59 AM
    #9612
    InCogNeatOh Parts
    Quick google says
    Yes, "chase lights" often, and effectively, utilize strobe or flashing features to increase visibility and warn those behind, especially in challenging conditions like dust or darkness.
    Here's why and some considerations:
    • Increased Visibility:
      Flashing lights, including strobes, are designed to stand out and attract attention, making it easier for drivers behind you to see your vehicle, especially when visibility is reduced due to dust, fog, or darkness.
    • Safety:
      Strobe lights can help prevent collisions by alerting other drivers to your presence and movements, allowing them to react accordingly.
    • Dust/Fog Penetration:
      The flashing nature of strobes can help cut through dust and fog, making them more visible than solid lights.
    • Tactical Environments:
      In off-roading or tactical environments, strobes can be used to cover movement or disorient an aggressor.
    • Legal Considerations:
      While strobes can be helpful, be aware of local laws regarding the use of flashing lights on civilian vehicles.
    • Types of Chase Lights:
      • LED Light Cubes: Small, compact LED lights can be easily mounted and used as strobes.
      • Wiring Harnesses: Some companies offer wiring harnesses that allow you to use your existing turn signals or reverse lights as strobes.
      • External Switch Panels: External switch panels can control the strobe function of chase lights.
      • Built-in Strobing Technology: Some chase lights come with built-in technology that allows them to strobe automatically.
  13. Mar 11, 2025 at 7:05 AM
    #9613
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    Just my preference but I think this is my issue with it. Makes it harder to tell whats goin on. Strobes make alot of sense for onroad driving where people are distracted on their phones
    Merling and GarlicFarts like this.
  14. Mar 11, 2025 at 7:09 AM
    #9614
    GarlicFarts
    Lil Rhody
    This is it for me. The strobe is more noticeable through the fog, so you can see the contrast more than just a light that's on.
    Boo yeah, time to use my tacoma as a weapon in reverse!
    Nah makes sense. Mine are also brighter than most dedicated chase lights so strobe probably isn't needed. I think last year was the first time I wasn't in the rear, so it wasn't a big deal other than then. I'll leave 'em solid and see what happens. :notsure:
  15. Mar 11, 2025 at 7:10 AM
    #9615
    InCogNeatOh Parts
    I agree, I can see both sides, if I don't strobe, makes the switch part easier. And if you approach a dust cloud in NMWs, I would hope you realize that something is causing the dust and you need to aware.
    However, we might piss of a local and may need to disorient someone chasing us.
    GarlicFarts likes this.
  16. Mar 11, 2025 at 7:12 AM
    #9616
    TacoTuesday603
    Jack
    New Hampshire
    2011 Tacoma TRD OR
    The capability could be useful. Sean might try and find you and your blue balls.
  17. Mar 11, 2025 at 7:38 AM
    #9617
    GarlicFarts
    Lil Rhody
    I played basketball once
  18. Mar 11, 2025 at 4:33 PM
    #9618
    GarlicFarts
    Lil Rhody
    Old smaller 20W panel on my roof. Using it as a device charger. Routed the cable down into the glove box and shoved all the stuff down into the body panel. Panel > pass through 10,000mAh battery bank > charging devices.
    Used to be scattered about the cab. Cleaned it up tonight, summers will charge a Bluetooth speaker and bike headlights for riding. Winter charges light up belts and dog collars for walking.
    I don't drive enough for the USB port in the center console to keep it charged, this will charge all day long now :)
    MarX, Justinogo, Merling and 3 others like this.
  19. Mar 12, 2025 at 5:18 AM
    #9619
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    CLEAN
  20. Mar 12, 2025 at 2:02 PM
    #9620
    Odlcjro01
    Lee
    Rhode Island
    Just got this message.
