New Exhaust = Worse Mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaWilly, Nov 21, 2019.
  1. Nov 21, 2019 at 4:49 AM
    TacomaWilly
    TacomaWilly [OP] Well-Known Member
    About six weeks ago I got the frame replaced on my 2006 DCLB TRD Sport. I got them to install new exhaust while they were at it; basically everything except the headers.
    I used to get 20 MPG, but now I am only getting 17 MPG. Seems like it is running rich.
    A few factors that may come into play;
    -Truck sat for two weeks while they worked on it (not sure how that would affect mpg though)
    -I don't believe the new exhaust system was OEM (but it was an equivalent)
    -Had to replace calipers as they would stick since didn't get used for two weeks
    -In terms of accelerating, the truck feels a lot heavier
    -Old exhaust system had a leak, it sounded like sh*t lol.
    -I drive about 45 miles a day, 35 of which are hwy.
    Given the price of fuel these days, it's bothering me that I spent $1400 on new system and got worse mileage out of it. I didn't expect it to be better, but I sure didn't expect it to be worse!
    I'd love to hear thoughts from you guys.
    Willy
  2. Nov 21, 2019 at 5:02 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    I would do all the normal things, clean the maf sensor, replace air filter, change spark plugs. disconnecting the battery and allowing it to reset might also help adjust to the new settings it has to run in order to get fuel economy.
    I havent heard anyone get worse mileage just from the exhaust, i would guess some other factor has crept up that either is affected by the exhaust, or something totally unrelated.
    also i would check the brakes arent sticking like you said,you can tell by sometimes they will glaze over, that is the most obvious. but jacking up the truck and trying to spin the wheel is the easiest and often the most telling
  3. Nov 21, 2019 at 5:03 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    More than likely it's a combination of things. For one, your battery would have been disconnected for a while so the truck has to relearn your driving habits and setting fuel trims, A/F mix, ect.. Second, depending on where you are in the country, winterized gas could play a small factor in the differences in fuel economy. You could run a bottle of that STP fuel system cleaner through a tank of gas to see if you get any difference in fuel economy. Given the age of the vehicle, your fuel injectors might be in the process of clogging up so a good cleaning could help out. Also, verify your tire pressure.
    -J
    supmet and TacomaWilly[OP] like this.
  4. Nov 21, 2019 at 5:04 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Not sure what all related exhaust was replaced. Did this change out include a new Catalytic Converter?
  5. Nov 21, 2019 at 5:06 AM
    TacomaWilly
    Yes, the cats on both banks are brand new.
  6. Nov 21, 2019 at 5:11 AM
    Lester Lugnut
    In my opinion there is no such thing as OEM equivalent when it comes to cats. I would find out exactly what you have and then start talking to the mfg. of the cats.
    TacomaWilly[OP] likes this.
  7. Nov 21, 2019 at 5:14 AM
    LoveableWerewolf
    Nashville
    oh yes, the switch from winter gas just happened. that is definitly what it is.
    stickyTaco and TacomaWilly[OP] like this.
  8. Nov 21, 2019 at 6:10 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I agree. OEM is built to Toyota’s specs by whomever is making the product. Anything else is made however that manufacturer wants. Still don’t need nderstand why people don’t get this.
  9. Nov 21, 2019 at 6:12 AM
    TacomaWilly
    Thanks guys, I appreciate your input.
    For what it's worth, I am going to clean the MAF Sensor, Throttle Body and try the STP Injector Cleaner. I'll let you know how it works out for me. Also I will check the manufacturer of the exhaust and see if anything is apparent with their system vs OEM
  10. Nov 21, 2019 at 6:45 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Reset the computer ECU too.
    revtune likes this.
  11. Nov 21, 2019 at 7:18 AM
    revtune
    revtune Dreaming of a 4.7 Tacoma
    Houston
    2007 Tacoma DCLB 4x2 4.0
    5100 front struts set on top perch trd sport coils Spc upper control arms 5100 rear shocks toytec add a leaf 1 inch rear block Longer U-bolts 17x7 SR5 (2014) 4Runner Wheels p285/70/17 Falken At3w AFE Stage 2 si with volant ram scoop MAF Calibrator 4.30 gears Undercover bed cap Weathertech floor liners
    Get a scan tool of some sort. I like the blue driver, then you can see what’s going on with your fuel trim numbers and o2 sensors. Are you getting any Check engine lights?
  12. Nov 21, 2019 at 7:34 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Not to worry - your truck needs to re-learn your driving habits because of the battery being disconnected (frame change). Wait a couple of weeks and recalculate. Your mileage will also be affected by outside air temperature. Depending where you are located this can and will be a factor.
  13. Nov 21, 2019 at 7:45 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    My guess: several things come to mind. Colder temps now than a month ago and winter gas also just happened, (I lost 2mpg from one fill up to the next) and most likely battery was disconnected while they worked on your truck and the ECU needs to relearn your driving habits. As for the truck feeling heavy, I'd focus on brakes sticking. My parking brake would stick sometimes and it could definitely be felt. I suppose if I did not know it was the brake sticking that it would feel like the truck was heavy. Could definitely be the brakes since they just tore your truck apart and reassembled.
  14. Nov 21, 2019 at 3:54 PM
    TacomaWilly
    Well, I grabbed a bottle of that STP super concentrate injector cleaner, cleaned my MAF sensor with some CRC and while I was at it I cleaned the Throttle Body. It was gunked up pretty good but all clean now. Almost seemed like it couldn't quite close completely. I had to push it with my finger to get it to be 100% shut. I don't know if that would be normal or not? (First time I've opened up the intake system) Any how it'll take a week or so before I can see if it made a difference and recalculate mileage. I've got an 06 so the only way I can effectively determine my mileage is distance driven/fuel burned. Thanks again for the input and I'll let you know the results when I see them. Hopefully. Lol.
    Willy
  15. Nov 23, 2019 at 7:11 PM
    SHANTOU
    SHANTOU Well-Known Member
    2014 MGM DCLB TRD SPORT
    17 MPG is normal!!
    Wixo, revtune and TRDSport10 like this.
  16. Nov 23, 2019 at 7:21 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    Oh ya dude I lost a ton of MPGs. But damn it sounds good!
  17. Nov 23, 2019 at 7:24 PM
    SHANTOU
    got to pay to play!!
  18. Dec 3, 2019 at 9:09 AM
    TacomaWilly
    Hey guys,
    So about two weeks ago I cleaned the throttle body and MAF sensor and used a bottle of that STP Injector cleaner. My MPG is up to 18.5 from 17. I've read that winter gas can cause a decrease in mileage by 10-20% so that's probably the culprit here. I never really noticed in previous years about my decrease in mileage during the winter time so unfortunately I can't say for certain it is the winter fuel but so far that's what it is looking like. Especially since the switch to winter fuel is done mid September, about 3 weeks before I got my frame/exhaust replaced. I guess I will have to wait until May when they switch back to summer fuel to see if my mileage increases then.
    Willy
    JustAddMud likes this.
  19. Dec 3, 2019 at 9:12 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Maybe, your frame was so rusted that it weighed a lot less and now since they replaced it it weighs a lot more. /s
  20. Dec 3, 2019 at 9:12 AM
    Wixo
    Hank
    Tint, LED interior
    *great
