NEW Expedition Series Lower Control Arms from TOTAL CHAOS
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Apr 23, 2019.
  1. Feb 19, 2020 at 11:37 AM
    #61
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  2. Feb 19, 2020 at 4:19 PM
    #62
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Happy to help!
  3. Mar 12, 2020 at 3:25 PM
    #63
    spartanhockey6
    spartanhockey6 My truck rattles, A LOT.
    Trevor
    Talent, OR
    2010 White Trd Sport
    Money Pit
    Man.... these came out in less than a year from the time I bought my stock lower replacements... Pretty cool that now its 100% bolt on. I spent like 2 hours trying to grind down the steering stop on the stock ball joint cradle haha, I should probably go back and do some more. I still worry about the contact between the cradle and the LCA though... there's definitely wear on the weld, this looks like a way better way to mitigate that issue.
    TOTAL CHAOS[OP] likes this.
  4. Apr 3, 2020 at 1:50 AM
    #64
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @TOTAL CHAOS can the secondary shock mount be temporarily used as a place for a limit strap? aka before a secondary shock/hoop has been installed?
  5. Apr 28, 2020 at 5:01 AM
    #65
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    @TOTAL CHAOS Where was that video comparing your LCA to stock in the vice, to show the reduced flex?
  6. Apr 28, 2020 at 7:06 AM
    #66
    TOTAL CHAOS
    Corona, CA
  7. May 6, 2020 at 8:27 AM
    #67
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    :spending:sent just waiting for people to get back to work and ship them already :annoyed:
    nudavinci64 and H3llRid3r like this.
  8. May 6, 2020 at 8:39 AM
    #68
    Jcmartin11b
    Jcmartin11b Well-Known Member
    Justin
    Los alamos,NM
    22 Tundra Trd Pro
    Right when i thought i had my LCA picked out...
  9. May 11, 2020 at 9:00 PM
    #69
    sentientprogram
    sentientprogram Well-Known Member
    Any update on how much this weighs in comparison to oem lca?
  10. May 12, 2020 at 5:49 AM
    #70
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Weight shouldn't be a issue at all since it is not being used directly on the tire with centrifugal force.
  11. Jun 16, 2020 at 4:41 AM
    #71
    Chris(NJ)
    08 Indigo 4x4 DC OR
    @TOTAL CHAOS Does the stock length LCA's have any changes built in to them to help correct alignment numbers? IE: built-in caster.
  12. Jun 16, 2020 at 7:11 AM
    #72
    TOTAL CHAOS
    Corona, CA
    No they are a stock replacement. Our UCA has more caster built in and we didn't want to add more into the equation with the lower.
    H3llRid3r and Chris(NJ)[QUOTED] like this.
  13. Oct 10, 2020 at 1:04 PM
    #73
    knarliman
    knarliman Member
    Iman
    2019 trd offroad
    Baja upgrade fox dsc and icon full kit
    I have wheelers super bumps with the spacer they provided, do I remover that spacer and add tc spacer or keep my spacer or add two
  14. Oct 10, 2020 at 1:06 PM
    #74
    fatfurious2
    David
    Ashburn, VA
    I only have the TC spacer and the superbump
    H3llRid3r likes this.
  15. Oct 11, 2020 at 6:06 AM
    #75
    knarliman
    knarliman Member
    Iman
    2019 trd offroad
    That’s a huge ass spacer I will throw that one on
  16. Oct 11, 2021 at 5:23 PM
    #76
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Just ordered a set from Poly Performance! Not sure I'll see any return on the investment regarding performance, but I just can't help myself. I love a beautifully machined/manufactured piece of kit. Wish me luck!
  17. Oct 11, 2021 at 5:33 PM
    #77
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    BTW... I'm fully expecting that I'll need to chop my cam bolts (seized)... Any recommendation on superior replacements?
  18. Oct 11, 2021 at 5:49 PM
    #78
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    Nice. You will definitely see an improvement off-road. I have the first version that required some cutting and grinding of the cradle to make room for steering. Overall there is less play and just a more solid feel imo. My buddy drove my taco after I put them on and noticed a difference as well. I noticed a small loss of “car” feel on the pavement though.... with that said my truck is planted on the road like a mfer. Just solid. It helped having a friend do the install, especially for lining everything up. Extra floor or bottle jack will work too.
    I ordered my lca bolts through the local Toyota dealer, might as well order some lower shock mount bolts while you’re at it for a swap or future use. Good luck man.
    Bertw192[QUOTED] likes this.
  19. Oct 11, 2021 at 6:26 PM
    #79
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Thanks for the feedback! Helps justify my purchase!
  20. Oct 12, 2021 at 9:38 AM
    #80
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    I like not worrying as much about a trail failure when I'm beating on the suspension....which is pretty often. FYI...the steering may feel fairly stiff at first until the uniballs get set. Took a couple of days for me.
