New Extang Solid Fold 2.0 tonneau installed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AlanKA, Nov 5, 2015.
  1. Jan 25, 2016 at 2:53 PM
    #181
    Krezz
    Krezz Well-Known Member
    Kevin
    Ontario, Canada
    '18 Tundra Platinum Crewmax
    All mod's listed on website - regarexpeditions.com
    I can try to remember and measure up the panel next time I'm out with the truck and a measuring tape. It doesn't feel like I lose much, as I can store everything down below, and the few higher sitting items I have to work with just sit out front of it. It comes off in like 2 minutes as well, if I do need access to the full bed for whatever.
    007TRUCK[QUOTED] likes this.
  2. Jan 25, 2016 at 2:56 PM
    #182
    007TRUCK
    007TRUCK Well-Known Member
    You mean total removal takes 2min? And nothing needs to be reapplied (seal) etc when reinstalling back on?
  3. Jan 25, 2016 at 2:59 PM
    #183
    Krezz
    Kevin
    Ontario, Canada
    Just 4 latches and I can have it all off. No reason to remove the anchors, as they slide inside the bed rail. If those need to come out as well, it's a total of 8 bolts... so that may take another 2 minutes. There's 2 hand twist latches which would be at the front of the bed, and then 2 pull downs near the tail end, and then fold it up, and push together 2 snazzy latches to hold it all together. So if it's really cold, or if you're taking your time, maybe 5 minutes it should all take. It took only about 7 minutes to install when I did it.
    007TRUCK likes this.
  4. Jan 25, 2016 at 3:20 PM
    #184
    007TRUCK
    Why do hey advertise these optional accesories needed? Are they not included in the package to complete the installation?
  5. Jan 25, 2016 at 3:20 PM
    #185
    Aaronp18
    Aaronp18 Well-Known Member
    Vancouver, BC
    2016 White Tacoma TRD Sport 4x4 DCLB
    They don't have foam pads anymore. It's all a rubber gasket along the bottom now!
  6. Jan 25, 2016 at 3:22 PM
    #186
    Krezz
    Kevin
    Ontario, Canada
    I have cleats already with my Tacoma, but some competitors trucks may not offer them... OR if you want to add more? From my understanding you can also add more rubber around the edges, but they included 2 foam stick pads that you stick in a small gap near the front of the bed, and so far that was more than sufficient to keep 99% of my water out, so I was happy with what it came with, as is. I didn't choose anything additional. I live in Canada, but I assume both are packaged the same.
    :canada:
  7. Jan 27, 2016 at 2:15 AM
    #187
    LaPorta
    LaPorta Well-Known Member
    Anyone yet confirmed and possibly ordered the little rubber inserts for the gaps in the bed? I saw earlier on this thread that they are 62541-0410 & 62542-0410.
  8. Jan 27, 2016 at 6:23 AM
    #188
    bhs6568
    bhs6568 Member
    2016 TRD Sport
    I received my solid fold 2.0 two weeks ago and it came with a supplemental bag inside the box with 2 foam stick ons to attach the ends of the head rail.
    orangerush and el_zorro1 like this.
  9. Jan 27, 2016 at 9:48 AM
    #189
    el_zorro1
    el_zorro1 Well-Known Member
    Zorro
    Northern Virginia
    I also installed solid fold 2.0 and it also came with the 2 foam pieces.
    :thumbsup:
  10. Jan 27, 2016 at 12:25 PM
    #190
    ThangzaTRD
    ThangzaTRD Well-Known Member
    SWO
    2016 TRD Sport BBPDCLB
    Pop n loc tailgate, LED Headlight, Foglights, Reverse and all interior lights. Weathertech floor mats. Carbon fibre tailgate inserts. Trifold hard top tonneau
    I have the extang 2.0 on my dclb and it fits perfect keeps everything nice and dry. Buy it yourself and install yourself it's really easy to install takes 10 minutes
  11. Jan 30, 2016 at 6:22 AM
    #191
    littlechilds
    littlechilds skyhawk
    Cowtown
    16 trd sport Upgrade package DCLB
    KO2 tires, TRD pro rims. BP skid plate, Extang 2.0 cover, dipped grill and badges
    So why the F*&k are 2 dealerships (including the one I've got my truck ordered from) refusing to install these?? They are ok with the oem or even a Bakflip HD which is also third party. I personally think the Extang looks great, but they say it does not fit properly.
  12. Jan 30, 2016 at 6:57 AM
    #192
    el_zorro1
    Zorro
    Northern Virginia
    That is strange...mine fits fine, and took me 30 min to install.
  13. Jan 30, 2016 at 8:00 AM
    #193
    maxxmagnum
    maxxmagnum Member
    I've been considering getting a cover for my Tacoma. This cover is the best looking one Ive seen. Doesn't look like water would puddle on the top like others. Thanks for posting.
  14. Jan 30, 2016 at 2:02 PM
    #194
    hec.brz
    hec.brz Active Member
    2016 DC TRD OFF ROAD
    all stock :P No money!
    This is the instructions that comes with when you purchase the solid 2.0 fucken crap says T30 but it's wrong my screw got stripped and I had to use easy out to get it out the correct size is T27
  15. Feb 1, 2016 at 2:39 PM
    #195
    el_zorro1
    Zorro
    Northern Virginia
    When I installed the seals, it did not strip, and I used the T30, 3/8" drive short extension ratchet. The T30 screwdriver I started with did not do the trick.
  16. Feb 1, 2016 at 5:05 PM
    #196
    HCTacoGuy
    HCTacoGuy Well-Known Member
    Homer City PA
    2025 Tacoma TRD Sport 4x4 Black
    Ready Lift SST 2.5 lift Method Black 703 17 x 8.5 +35
    Fits perfect on mine. I think they are FOS.
  17. Feb 5, 2016 at 12:46 AM
    #197
    hec.brz
    i used a drill lmao maybe thats why ahaha
  18. Feb 5, 2016 at 3:26 AM
    #198
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    It is a T-30. I broke them free with a ratchet then ziped them out with my impact.
    One thing I noticed on install was the rear most screw for the bracket was too long and hit the factory rail bolt before being tight. Took care of it with the grinder. And the rail covers dont fit back on with the brackets installed.
  19. Feb 5, 2016 at 12:44 PM
    #199
    Wittyusername
    Wittyusername Active Member
    2016 MGM Tacoma
    Picked mine up from Luke @ Truck Alterations for $680 shipped. Installed today in 10 minutes. ecb638385a8030e579d47364b61597e7_d96c64cf5bec03f9d0f609a545e0eb76972e8f70.jpg
    Woody79 likes this.
  20. Feb 5, 2016 at 1:08 PM
    #200
    ORDR
    ORDR New Member
    2016 TRD OR DCLB 4x4 V6 Auto MGM
    Extang Solid Fold 2.0 Tonneau Toyota All weather mats, mud flaps and DSP LED interior lights
    I put mine on the other day.
    Long bed if that makes a difference
    T30 worked fine for the front rail for me, broke it free with a ratchet then used the drill for speed.
    Had to put the back brackets as far back as they would go in the rail, with just enough space for the end caps to fit back in. Tolerances were very tight, like only millimeters to spare in the rear. I can see a dealer who didn't want to spend time tweaking it would say "It doesn't fit".
    But since then works great! Dry in the back in PNW rain, easy to remove single handed, looks good.
