New Falken Wildpeak AT4W ????
Discussion in 'Wheels & Tires' started by TacoPandaTRD, Dec 27, 2023.
  1. Feb 6, 2024 at 11:27 PM
    #281
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I know it's 3ply on the side and 10 where the tread is:notsure:
    I think I understand what your saying
    I just know I've had better luck with e rated is all I was saying:cheers:
  2. Feb 7, 2024 at 8:10 AM
    #282
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    My understanding is that its a "ply rating" and we no longer - in any tires, sidewall, tread or otherwise - use actual number of plies when it comes to load ratings. Manufacturers may state the number of plies but this is just info and not at all related to ply rating. https://www.lesschwab.com/article/tires/tire-ply-ratings.html
    It's not a surprise that "generally" E rated tires are more durable than non E rated tires. And, if you have lots of experience offroading, especially if this is multiple decades of experience, then that correlation is even stronger. My point is that with more modern tires this is not a fool proof method of tire shopping and that you're likely missing out on some good options if you're limiting yourself only to E rated tires. There are going to be some non-E-rated models which are actually more durable than some E rated. Basically newer tech and newer materials have made it possible to create stronger, more durable tires with fewer layers. So comparing the plies of today with the plies of yesterday is like apples to oranges.
  3. Feb 7, 2024 at 8:55 AM
    #283
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    For sure
  4. Feb 7, 2024 at 7:58 PM
    #284
    OGTodd
    OGTodd Member
    Lewis
    84,88,90 SR5 23 TRD DCSB
    84 dual case,5.29’s 37x14.50 Iroks
    I lined up with the yellow valve stem marker and just added the beads. I’ve never thought about the bigger beads? I haven’t gone below 15 psi without bead locks.
  5. Feb 8, 2024 at 6:14 AM
    #285
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    Just put a set of these on my truck, so far so good. Way quieter than the duratracs.
    Road_Warrior likes this.
  6. Feb 8, 2024 at 7:30 AM
    #286
    va4tacoma
    va4tacoma Member
    2011 Tacoma off-road
    Did you ever get more pictures of your truck with the new LT255/85/16 AT4Ws mounted? I also wanted to ask you about the weight. Do you feel that they are too heavy for the Tacoma? I'm having second thoughts about these because of the weight. I have a 4.0 MT so I may be ok, but I'm kind of worried about the weight. Thanks!
  7. Feb 8, 2024 at 8:22 AM
    #287
    clenkeit
    Colin
    Lakewood, CA
    It's been raining/flooding here so I've been driving my truck (instead of my lowered daily driver). So far my 255/85R16 have been great in the rain. But, the rain also means I haven't had time to take more pics or measurements or anything. They look good, but I gotta admit I kinda miss how aggressive the G003's looked. But I do not miss the road noise and rough ride. Not sure if I can feel the extra weight yet, I've had nearly 800lbs in the bed so that's kinda making it hard to tell. But just got that shit outta there so can now really start to pay attention to how the new tires feel. Also gonna be a little while until I get a tank or two of gas thru it so I can see about mpg. Planning a short trip out to the desert in a month so that'll be my first time to test them offroad.
  8. Feb 8, 2024 at 10:19 AM
    #288
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    They look fine, like any other A/T pretty much. Those G003s are sick though. I think the Ridge Grapplers are a good-looking tire also.
  9. Feb 8, 2024 at 1:12 PM
    #289
    track.n.trail
    track.n.trail Member
    Owen
    SF Bay Area
    2013 DCSB TRDOR TX Pro
    Are you on stock gears still? I was considering going with the 255/85r16's but ordered 265/75r16 instead since it's my daily driver and I don't want any driveability issues with the AT transmission or using OD on the highway.
    And have you had any rubbing issues with this size? I've got the same wheels.
  10. Feb 8, 2024 at 1:31 PM
    #290
    clenkeit
    Colin
    Lakewood, CA
    Yeah, stock gears. TONS and TONS of people are running 33's on stock gears. Most are running the slightly smaller 285's but also plenty that run the larger 255's. So far this hasn't been a problem for me. I had 265/75R16 prior to stepping up to a skinny 33" and I didn't notice any difference in drivability in terms of gearing. To me this truck is slow and guzzles gas regardless of tire size or weight, lol. But I've also never driven it stock form since the prior owner had 285's on it when I bough it.
    Stock gearing probably isn't ideal but it seems 33's are still OK. I'd love to drive a truck that was regeared specifically for 33's to see how it drives. Regearing is quite an expense so as much as I'd love to do so in order to have a "perfect" setup I'm gonna stick with "fine" for now. If someone can prove to me that I'll see a big increase in mpg and that it'd drastically improve how it drives, then I'd surely start saving for a regear.
    I can't really speak to rubbing, unfortunately. My truck already had the bumper and mudflaps clearanced by the prior owner for his 285's and low offset wheels. When I installed my 255 G003's I had a tiny bit of rub so took the mudflaps off and clearanced the fender liner a tiny bit with a heat gun. But that rubbing was minor and will vary a lot on your specific suspension and alignment settings. No new rubbing now that I've got the AT4W's installed.
  11. Feb 8, 2024 at 2:46 PM
    #291
    va4tacoma
    va4tacoma Member
    Looks good! How much lift do you have in the front and the rear??
  12. Feb 8, 2024 at 3:46 PM
    #292
    clenkeit
    Colin
    Lakewood, CA
    I'm not entirely sure what the exact measurement is since I bought my truck with a lift on it already and then have went thru a few different setups already and have some weight from skids/sliders. But... best I can tell it's ~2.25" front and rear.
    Front = TRD Pro Bilstein coilovers (6112) + Toytec Baja spacer
    Rear = TRD Pro Bilstein shocks (5160) 3rd gen leaf pack + Headstrong AAL (w/ overload left in)
    (I plan to replace the AAL with an Icon RXT leaf pack set to stage 2 soon. Hoping for the same amount of lift but with better performance.)
    TacoPandaTRD[OP] likes this.
  13. Feb 9, 2024 at 10:44 PM
    #293
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I'm looking at getting a set of these to use in the winter for ski season. I'll be driving 2-3 hours with decent HWY/FWY speeds combined with snow, slush, ice on the way up and down the mountain roads. Any guesses on which one would and get better MPG's?
    255/85r16 C Rated 58.4 lbs
    285/70r17 SL Rated 53.4 lbs
    What affects MPG more? Width? Weight? Load rating?
    Moto521, Tacolife5 and Road_Warrior like this.
  14. Feb 10, 2024 at 12:47 AM
    #294
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    Great question. I’ve been wondering the same thing.
    boostedka[QUOTED] likes this.
  15. Feb 10, 2024 at 6:09 AM
    #295
    RD8761
    RD8761 Member
    2019 Quicksand Tacoma TRD Off-Road
    I am by no means an expert, but from what I have read and understand the narrower tire will cut the slushy snow easier and get in contact with the pavement. Wider tires will “float” easier. As far as mpg’s are concerned, you need to consider the weight of your wheels as well. The combined weight is what the truck needs to turn. I have tried a combined 85 pound wheel/tire package on a stock ‘19 TRD OR in central Indiana and my truck would gear hunt on the slightest of grade increases. Installation of an Anderson Engineering manifold spacer plus the KDMax-Pro tune have done wonders for performance. I’m getting the 255/85/16’s installed on Toyota 16” beadlock style wheels (23.5#) next week. I’ll post a review after driving on them a bit.
  16. Feb 10, 2024 at 6:36 AM
    #296
    boostedka
    James
    NM
    That makes alot of sense. The total weight would probably be even Steven. The 16’s I have are 19lbs and the 17’s are 25lbs. Helpful to hear about the width difference in snow on pavement. I’ll have to look up more info on that.
  17. Feb 10, 2024 at 11:12 AM
    #297
    cyisalwayshungry
    cyisalwayshungry Member
    San Diego
    FJ Cruiser
    TRD 2007, Goodyear MT/R 285/75-16
    IMG_9788.jpg IMG_9784.jpg IMG_9786.jpg Thanks to Jordan from Discount Tire for helping me get my pizza cutters for my FJ. 255/85-16. Loving it already compared to my 285 KO2s.
  18. Feb 10, 2024 at 3:33 PM
    #298
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    Damn! Looks good!
  19. Feb 10, 2024 at 5:09 PM
    #299
    track.n.trail
    Owen
    SF Bay Area
    Well, you convinced me. I switched my order to the 255/85r16s. Now I need to get my 6112s installed ASAP
    clenkeit[QUOTED] likes this.
  20. Feb 12, 2024 at 10:07 AM
    #300
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    The rig looks fantastic! Thank you for allowing us to be a part of your tire purchase journey. Glad your loving the tires.
