New Falken Wildpeak AT4W ????
Discussion in 'Wheels & Tires' started by TacoPandaTRD, Dec 27, 2023.
  1. Mar 14, 2024 at 4:11 PM
    #381
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Pics?
  2. Mar 14, 2024 at 4:26 PM
    #382
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Smooth. Not harsh at all.
    boostedka and Road_Warrior like this.
  3. Mar 18, 2024 at 8:55 AM
    #383
    GritCyclone
    GritCyclone Member
    2015 TRD Off Road 6-Speed Manual
    I ordered and had these installed on Saturday. So far I really like them. The ride does not seem much harsher than the KO2s I had on previously and they seem to be much quieter.
  4. Mar 18, 2024 at 9:43 AM
    #384
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    @Discount Tire I decided to get fancy with some pics highlighting the tires!
    They look pretty great to me, love these tires.
    285/70r17
    Eibach adjustable coilovers in the front
    ICON RTX stage 1 in the rear
  5. Mar 18, 2024 at 10:02 AM
    #385
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    We would have to agree! The Taco looks fantastic! Thank you for allowing us to be a part of your tire upgrade.
  6. Mar 18, 2024 at 10:06 AM
    #386
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Looks great!!
  7. Mar 18, 2024 at 3:17 PM
    #387
    boostedka
    James
    NM
    Looks sweet! Are those genuine TRD wheels or replicas?
  8. Mar 18, 2024 at 8:10 PM
    #388
    Sand_In_My_Taco
    NOR*CAL
    Reps. I've had them for a few years now.
    boostedka[QUOTED] likes this.
  9. Mar 18, 2024 at 8:35 PM
    #389
    nioking
    nioking Well-Known Member
    Such a good looking tire.
  10. Mar 19, 2024 at 9:50 AM
    #390
    Two Track Rick
    Two Track Rick Well-Known Member
    2014 Toyota Tacoma TRD Sport
    So I have a question for everyone.
    Recently I did the chalk test on my new AT4s, and according to the results, I should be running about 26-27 psi in the unloaded rear to make the full width of the tread contact the ground, and around 32 psi in the front. Does 26-27psi seem too low for daily driving?
    I regularly see members here getting 50K+ miles out of their wildpeaks, and the furthest I've gotten with mine is maybe 35k, so I'd like to make these last as long as possible through proper inflation and regular rotations.
  11. Mar 19, 2024 at 11:41 AM
    #391
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    You are an aggressive driver aren't you! (J/K) that is what Discount Tire always says to me.
    Discount Tire likes this.
  12. Mar 19, 2024 at 12:02 PM
    #392
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    What size are they?
    And what size is OEM for your model?
  13. Mar 19, 2024 at 12:41 PM
    #393
    Two Track Rick
    Sorry - should have included.
    Currently riding on 265/75/16.
    OEM was 265/65/17.
  14. Mar 19, 2024 at 2:20 PM
    #394
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    There's no way I'd be running anything under 29/30psi.
    Are those LT's you're running now?
    If they are, you will probably be better off around 32-35psi. I'm not a fan of the chalk test, it does not factor in a new tires load capacity.
    You can also use this to help get your psi to a more accurate number:
  15. Mar 19, 2024 at 2:26 PM
    #395
    boostedka
    James
    NM
    Sweet. Reason I am curious is to figure out the wheels width and offset specs. Thanks
  16. Mar 19, 2024 at 2:50 PM
    #396
    Sand_In_My_Taco
    NOR*CAL
    Using the above calculator I "should" be using 26psi
    OEM Size (P265/70R16 SL) Load Capacity: 2326 lbs. @ 32 psi.
    New Size (P285/70R17 SL) Load Capacity: 2480 lbs. @ 26 psi.
    boostedka likes this.
  17. Mar 19, 2024 at 3:36 PM
    #397
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Yes that makes sense, since you’re staying with a SL tire
    I’m sure going up a few more psi wouldn’t hurt. Esp if you’re triggering tpms
  18. Mar 19, 2024 at 4:32 PM
    #398
    Andrew.arw
    Andrew.arw Chief Beer Officer
    South Carolina
    2018 Toyota Tacoma TRD OR 3.5 V6
    *** Current Setup - 2/27/24 *** - Wheels // Method 316, 17” - Tires // 275/70/R17 // Falken WildPeak A/T4W - Suspension // 2.5” lift // Eibach’s Pro lift, Stage One - front & rear // Eibach Pro Springs // Icon AAL // TC UCA’s - Lights // Rigid Industries Dual Pod’s [Grille] // Rigid Industries Dual Pod’s [Rear Bumper] // Rigid Industries 40” LED Bar [Roof Rack] // XenonPro Hi/Lo Beam // LASFIT Switchback Fogs - Auxiliary // Switch-Pro controller, SP-9100 Series - Audio // Rockford Fosgate R500X1D Amplifier // Dual Rockford Fosgate P1 10" Subs - Accessories // TRD Pro Grille // Prinsu Roof Rack // Rough Country Soft Tri-Fold Tonneau - Armor // Body Armor Rear Bumper, 4x4 Desert series // TRD Pro Skid Plate - Misc Mods // ECGS Bushing // Cali Raised AC Drip relocate // CMC
    Makes me wish I’d have gone 285! I can fit it with my CMC now haha. Looks great.
  19. Mar 19, 2024 at 7:20 PM
    #399
    Two Track Rick
    Not LTs. I'm running 28-29 rn and it's still a pretty comfortable / sturdy ride.
    TwinTaco31719 likes this.
  20. Mar 19, 2024 at 7:22 PM
    #400
    Two Track Rick
    Maybe I'm not too far off then.
