New Features on Tacoma World
Discussion in 'Site News and Announcements' started by tcBob, Sep 9, 2006.
  1. May 2, 2015 at 3:05 PM
    #701
    ThomasMore66
    Dallas/Fort Worth & Durango
    I came back and found you guys still here...
  2. May 2, 2015 at 5:22 PM
    #702
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Take a look at the front page on mobile. You'll see the last poster now...
  3. May 2, 2015 at 5:26 PM
    #703
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Quotes don't seem to work for me on mobile.
    Is it me or?
    I was going to say editing didn't work either but obviously it did this time
    ... and quote just did too
    nevermind
  4. May 2, 2015 at 5:28 PM
    #704
    tcBob
    Bob
    What happens exactly when you try to quote on mobile, that shouldn't happen?
  5. May 2, 2015 at 5:33 PM
    #705
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I had a quote not work for me yesterday too , I quoted a post via Tapatalk and it looked like it should , somebody commented on me not being able to quote correctly so I switched to Full Site and the quote was not in the regular quote box , it just showed all of the [ QUOTE ] type stuff
  6. May 2, 2015 at 5:34 PM
    #706
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Earlier today, if I hit quote or edit the page had no box to type in.
    Working fine now.
  7. May 2, 2015 at 5:34 PM
    #707
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  8. May 2, 2015 at 5:35 PM
    #708
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmmm
  9. May 2, 2015 at 5:38 PM
    #709
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Seems to work, but there is a slight delay. When you hit "quote" it takes about 1 second for the text to show up. If you hit the quote button, then begin to type immediately, then post, the quoted text doesn't post. If you wait to submit after typing your reply, the text shows under your reply. If you wait for the quoted text to appear before typing your reply, all works as normal.
  10. May 2, 2015 at 5:41 PM
    #710
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I was already used to seeing the last poster in landscape mode, but not portrait. The front page looks good in portrait, but horrible in landscape mode.
  11. May 2, 2015 at 6:48 PM
    #711
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    To add to that silliness, if I type the first word using swipe it will show up inside the first "[" for the quote code despite the fact that I have the cursor a line after the entire quote.
    That's merely a comment, not a complaint.
  12. May 2, 2015 at 7:03 PM
    #712
    replica9000
    2019 T4R ORP
    X2. Thought maybe it was the keyboard on my phone.
  13. May 2, 2015 at 7:07 PM
    #713
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Is it just my iphone or is the "alerts" tab on the top right of the main page (non-mobile version) invisible?
    It works great on my laptop, but on my phone all I see is the little red numbers for alerts, no actual alerts tab. I do however see "Snowman" & "inbox"
  14. May 2, 2015 at 7:25 PM
    #714
    Jas
    Jas Space still for sale. I do not accept checks.
    SoCal
    99 4runner Limited
    It's invisible on my tablet as well. Not sure whether I was in mobile mode or not though.
  15. May 3, 2015 at 5:10 AM
    #715
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X3 on desktop veiw on phone. @tcBob
  16. May 3, 2015 at 5:21 AM
    #716
    replica9000
    2019 T4R ORP
    TW ignores my browser's request for desktop view on my phone.
  17. May 3, 2015 at 6:34 AM
    #717
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    Is there a way to view "trending" threads, like the ones that have been getting the most posts in the past 12 or 24 hours?
  18. May 3, 2015 at 7:27 AM
    #718
    tcBob
    Bob
    Pm me about this so we can resolve it.
    no there's no existing feature like that at the moment
  19. May 3, 2015 at 7:29 AM
    #719
    tcBob
    Bob
    And I'm guessing iPhone too?
    Just did desktop view on my android phone and I can see the alerts tab fine, so might be an iOS thing I need to fix
  20. May 3, 2015 at 7:47 AM
    #720
    replica9000
    2019 T4R ORP
    Home page is squished in landscape mode on mobile
