New Features on Tacoma World
Discussion in 'Site News and Announcements' started by tcBob, Sep 9, 2006.
  1. Apr 26, 2015 at 7:34 AM
    #121
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    DefconBrix and tcBob[OP] like this.
  2. Apr 26, 2015 at 7:34 AM
    #122
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Subbing this, change takes me a hot minute to get used to
  3. Apr 26, 2015 at 7:49 AM
    #123
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Niccce...... Thank you for your time and effort..
  4. Apr 26, 2015 at 7:52 AM
    #124
    Tacoma Mike
    Southern Maine
    What's up with having to expand thread posts???
    That's a royal PITA....
  5. Apr 26, 2015 at 7:56 AM
    #125
    ThomasMore66
    Dallas/Fort Worth & Durango
    But not the sig pics?
  6. Apr 26, 2015 at 7:58 AM
    #126
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Subbed... Looks good, may take a bit to learn the new features
  7. Apr 26, 2015 at 8:00 AM
    #127
    mlbdriver
    mlbdriver Well-Known Member
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Go Fast Camper ARB Dual Air-Compressor Pro-Comp 7089 17x8 BFG AT KO2 265x70x17
    How do you add the Fuelly thing to your signature????
  8. Apr 26, 2015 at 8:00 AM
    #128
    woodyc
    woodyc Well-Known Member
    Craig
    Oceanside, CA
    2014 Access Cab 4x4 TRD
    Sway Away 2.5 " Coilovers Sway Away rear shocks Dakar rear leafs (3rd leaf removed) Snug Top Sport Highliner Shell Thule Racks Toyota Bed Mat Weather Tech Floor Liners
  9. Apr 26, 2015 at 8:01 AM
    #129
    mlbdriver
    Ben
    Santa Rosa
    2020 TRD Off-Road
    Also i like the new upgrade only thing is it is a litttle bright
  10. Apr 26, 2015 at 8:02 AM
    #130
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Good work Bob, thanks for taking care of us!
    DefconBrix likes this.
  11. Apr 26, 2015 at 8:03 AM
    #131
    mlbdriver
    Ben
    Santa Rosa
    2020 TRD Off-Road
  12. Apr 26, 2015 at 8:04 AM
    #132
    The Hunter
    The Hunter Sailing the high Puddle's
    Hunter
    Monroe NJ
    2011 Submarine
    Flux capacitor and bi-plane wings
    I like what youve done with the place Bob!
  13. Apr 26, 2015 at 8:04 AM
    #133
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I was thinking the same thing. I'll probably get used to it, but the interface looks washed out compared to the old look. Bugs my old eyes a bit.
  14. Apr 26, 2015 at 8:05 AM
    #134
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    so when in mobile view and you toggle desktop view how do you get back to mobile view???? the toggle is gone
  15. Apr 26, 2015 at 8:08 AM
    #135
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Is Tapatalk still active?
  16. Apr 26, 2015 at 8:09 AM
    #136
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    WOW! Lots of cool new stuff! Love the tagging feature and drag and drop. Like others though I really dislike the color scheme...
    Question: What does the "likes" by my name mean?
  17. Apr 26, 2015 at 8:10 AM
    #137
    Harley2
    Harley2 Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    How the heck do we start a new post?
  18. Apr 26, 2015 at 8:13 AM
    #138
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    @tcBob
    Thanks again Bob.
    Ima guessin' ur not gettin anything else done today either.
    Couple questions, maybe already addressed, if so, my apologies.
    No email updates, this am. Do I need to do anything?
    On a forums list page, such as "Site News and Announcements",
    The thread "New Features on Tacoma World" has the number of replies in a column to the right.
    In the old version, one could click on the "number" of replies and get a list of members and their number of posts in that thread.
    Then by clicking on a specific member's number of posts, it would display all their posts in that thread.
    It was quite useful, when/if looking for a specific older post by someone.
    Any chance that might become available as you work thru all your other self-inflicted issues?
    Again, thanks and my compliments on setting up a great site for the masses.
    CC
  19. Apr 26, 2015 at 8:13 AM
    #139
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    If this works - Thanks.
  20. Apr 26, 2015 at 8:14 AM
    #140
    george3
    New Jersey
    Looks like it did work so thanks BOB
