New Firestone AT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kcjownz31289, Nov 18, 2015.
  1. Nov 18, 2015 at 5:51 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    A not uncommonly overlooked attribute,723rdCAT.
  2. Nov 18, 2015 at 5:54 PM
    addicus24
    Good to hear. What do they most commonly install on the OR now?
  3. Nov 18, 2015 at 6:08 PM
    addicus24
    What PSI do you guys that were blessed by Toyota with Rugged Fails run. Had my tires rotated at 5000 miles by dealership today. They put 36 PSI in all 4 tires. Yes, I even marked my tires as per TW recommendation, before I took my truck in. They changed my oil and rotated my tires in 24 minutes. Didn't even have an appointment. Just called and they said, "Bring her in now if you want to". Filter was changed and oil is new. Good service. Still don't like anybody messing with my baby Taco. Kinda made me feel like I did when I was 18 years old and my girlfriend went to the OBG.
  4. Nov 18, 2015 at 6:12 PM
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    I don't know for sure honestly I pulled an uneducated voter move there and had read that '16s had better tires and assumed it is true.
    Now uh....hey look at that flying squirrel over there!
    So far as the stock are concerned Toyota should be setting them to whatever the door sticker says which for the SR5 and the Dunflop Grandturds those where 30 PSI all around. Of course that sticker applies to the tire the truck was built with. I suppose the best thing is to call the tire manufacturer and see what they say.
    Of course I read in a thread on tires here that a guy was told by the maker for his Taco they said a higher PSI for the rear tires which surely is not correct in fact that could even cause a loss of control I would think if the bed was empty and you hit say a rut in the road in a turn the tail end would bounce up and before you knew it your tail gate would be ahead of you.
    addicus24 likes this.
  5. Nov 18, 2015 at 6:26 PM
    subsonic
    subsonic Member
    Little research shows they are using Firestones and Goodyears. Finally, something better than those damn Dunlops.
  6. Nov 18, 2015 at 7:39 PM
    g60gti
    g60gti Well-Known Member
    K
    WNY The Ruff Buff
    I've had my 265 70 17 destination at's on my 07 dclb for 15,000 miles now and have no complaints. Excellent in the snow up here in western NY. I just bought SR8's and am trying to decide on tires, might go with the destination MT's.
  7. Nov 18, 2015 at 8:12 PM
    723rdCAT
    Kentucky
    I had seen Goodyears I believe on ORs that I saw awaiting delivery prep in the back lot at the local Yota dealer. I see that the 16 has the exact same steering wheel as the 12-15 dose. I wonder if the better tire has to do with the deletion of the 5 luggers as they used the Grandtreks as well could be a factor for the base thru SR5 trims.
  8. Nov 19, 2015 at 9:46 AM
    addicus24
    Had my tires, Rugged Fails, rotated at dealer yesterday. Checked PSI this AM and they had my PSI set at 36 front and 32 rear also. What is their rational for this? Could they have noticed my tires wearing funny, or something, and are trying to correct the wear pattern with this PSI set up? The Service/Inspection sheet they gave me said they adjusted all four tires to 36 PSI.
  9. Nov 19, 2015 at 10:02 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    The front of the truck is heavier than the rear?:notsure:
  10. Nov 19, 2015 at 10:05 AM
    addicus24
    Could be.
  11. Nov 19, 2015 at 10:19 AM
    talofox
    talofox Northwest Member
    Justin
    Port Angeles, WA/Minot,ND
    '07 DCSB 6spd
    The 265/75/16 Destination AT are the best upgrade to stock or slightly lifted Tacomas IMO. They are awesome in snow/ice too, would be even better if the Tacos ABS wasn't a deathtrap on icy roads.
    tacoparadise and R0dzilla75 like this.
  12. Nov 19, 2015 at 7:12 PM
    723rdCAT
    Kentucky
    That is exactly why. Even empty there is more weight on the front tires (with any front engine vehicle) with a car this matter less as the weight is distributed more evenly. With a pick up truck there is a lot less weight on the rear tires unless you have nearly the same or more weight in the bed or in tow.
    Having the rear PSI lower provides a better more responsive ride as once heated from driving the PSI will usually be about the same front and rear in this case. With same PSI front and rear cold chances are the rears will be higher at road temperature which will make the ride a bit rougher. Id say this effect is more noticeable with all terrain tires because they have thicker sidewalls and thus a stiffer ride than an all season (the stock Dunlops are supposedly all season) tires which have much thinner more flexible side walls.
    To some extent its up to the driver what they prefer and weather they are most concerned about better MPG(higher PSIs) or greater ride comfort(lower PSIs).In addition the higher the PSI the more responsive the ride and vice versa. All this is concerning driving on a hard top road. When off roading lower PSI is better many run down to 15-20 PSI for trail driving.
  13. Nov 19, 2015 at 7:13 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Decent tires....... I melted mine when I got boost tho
  14. Nov 19, 2015 at 7:16 PM
    va_bank
    va_bank Well-Known Member
    2015 TRD Sport LB
    Had them on my 4Runner that I traded for the Taco. 25K miles and they still looked new. Will get the same ones when I get new wheels
  15. Nov 19, 2015 at 7:16 PM
    #35
    723rdCAT
    Kentucky
    LOL. @ Justus
  16. Nov 19, 2015 at 7:20 PM
    #36
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  17. Nov 20, 2015 at 4:46 AM
    #37
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    I was so close to getting these, my common sense got to me and got the michelin defenders for the mileage and ice traction, had good luck with them on the xterra. Mos tof my driving is on road.
    For the life of me i cant figure out why the off road recommends 29 psi front and 32 back for the 265 70 16 tire. Been wondering if i can up the front a little.
  18. Nov 20, 2015 at 11:46 AM
    #38
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    because many people buy trucks but they cry if it rides like...... A truck. So to keep them pacified, Toyota not only runs the tires low, but in the US, we have also had weaker leafpacks since 2005.
  19. Nov 24, 2015 at 10:21 PM
    #39
    Shark18
    Shark18 Well-Known Member
    Daniel
    2007 White dbl cab Tacoma 4x4 TRD
    On my second set of these bad boys got 80k last set. Living in Mexico the roads are not the best these guys hold up well. The BFG's I had first tore the sidewalls out.
  20. Nov 24, 2015 at 10:45 PM
    #40
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I've asked myself the same question.
    I understand that the fronts heat up more due to the additional weight/friction from the engine/turning. So when the tires are at hiway temps, they should be about the same. Maybe the front even a little higher pressure than the rears when hot. That makes sense to me.
    Seems the fronts would require a higher pressure if you were to do a chalk test. If the above is true, then all is well.
