New fog light install
Discussion in 'Lighting' started by tundrataco, Apr 8, 2014.
  1. Apr 8, 2014 at 1:13 PM
    tundrataco
    tundrataco [OP] Well-Known Member
    eastern townships, quebec
    front bilsteins 2.5" lift, rear aal 2.5" lift, flowmaster 40 series muffler, kenwood headunit, ultraguage, allpro bolton sliders
    so thanks to all your help guys, i am finally ordering my fog lights and zombie lights rocker switch to install on my 07 taco that doesnt have fogs. i checked under the bumper and i have the pigtails, and i took out the first blocked switch cap (for fog lights) and i have the 4 prong wire harness there, so heres what i ordered, also since the wiring is already in the truck, will i need to buy a relay or will the one that comes in this kit fit in the relay box? or will i need to hook it up seperately?
    fogs
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181271931007
    rocker switch
    http://www.otrattw.com/proddetail.php?prod=VVPZCZL-1ZL
  2. Apr 8, 2014 at 1:18 PM
    tundrataco
    just had a break in the rain outside, i do not have a relay in the fog spot, so im wondering if the relay supplied with this kit will fit in? i hope so, if not i guess ill have to get one from the dealer.. the kit i bought says direct oem fit so..
  3. Apr 10, 2014 at 5:17 PM
    coopjl
    coopjl Well-Known Member
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    ARB Deluxe bull bar ARB Fog lights ARB Driving lights 24" Vision X Light bar ARB Rear locker w/4.56 ARB Front locker w/4.56 ARB Compressor Warn M8000# winch OME HD suspension CBI rock sliders CBI Trail Rider rear bumper with tire carrier and fuel can carrier Lear Topper with wilderness package TRD Matte Black Wheels SlimLine FrontRunner II Roof rack
    How did you figure out which wires from the factory switch (4 wires) went to which of the 3 terminals on your rocker switch?
  4. Apr 10, 2014 at 5:55 PM
    tundrataco
    havent done it yet, but if you buy a switch from otrattw.com they have wiring diagrams, then im gonna use a test light to see what has power when..
  5. Apr 10, 2014 at 9:17 PM
    coopjl
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    My switch did not come with any diagrams...Still trying to figure the wiring out. Already blew a fuse and lost my heater/fan backlighting :mad:.
  6. Apr 17, 2014 at 8:56 PM
    tundrataco
    ok so heres what i did.
    first ran the switch wires (2 green, a black and a blue) through firewall.
    took white power wire to + on battery.
    took both black wires (one for fogs, one for relay and ran to - battery)
    took green (ignition wire) and ran it to my parking light driver side green wire.
    then i tried it with the switch they sent with kit. didnt work. found the relay was a kind of flimsy housing and i bent the power in tab, fixed that ok.
    so my otrattw switch is a spdt switch, it has 5 terminals.
    heres the link for the paper that came with my switch.
    http://www.otrattw.com/wiring/J66a.pdf
    first i put my black wire (-) on #8, and jumped it to # 7 like the diagram says. its for led illumination.
    then i took the blue wire and put it on the # 3 terminal.
    then there are 2 green wires, i took a chance and put them on #2 for power in, and #6 for the other led, tried it and everything works fine!!
