New frame is being installed!.... but here's what needs to be fixed on the truck :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BTR, Jan 11, 2015.
  1. Jan 11, 2015 at 12:19 PM
    BTR
    BTR [OP] Well-Known Member
    Mass
    06 Tacoma 4x4 v6
    One of the front shocks "exploded" so they said both have to be done (however they will do it at a reduced labor rate) 390$
    Bad U joint 283$
    Steering system rack needs to be replaced
    Pump
    Lines
    Intermediate shaft frozen
    1674$
    total 2347$
    They said if the rack is put in when the frame gets swapped its only 30mins of labor if not then its 7 hours..., they are also using a NAPA steering rack.
    Does that seem a bit high for the rack, pump, lines and intermediate shaft?
    I'm even more upset about the shocks, they go for about 150$ and I can install them myself! ack
  2. Jan 11, 2015 at 12:36 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    They are doing the rust recall? If so they are being paid 40 hours to remove almost everything and transfer to the new frame. I don't see how they can charge you labour for the shocks or rack
  3. Jan 11, 2015 at 12:40 PM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    Yeah, they're double dipping. I can see paying for new parts but getting paid twice on labor? Really!?!?
  4. Jan 11, 2015 at 12:56 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Check out the Napa website to see how much they want for the rack. Compare it to how much the stealership wants to charge you for the same thing.
    If it were me, I would tell them to just change the fucking frame and take care of the rest on my own.
    $283 for a u-joint?? Yea, they are screwing you
  5. Jan 11, 2015 at 1:20 PM
    fixnfly
    S.W.PA
    $336 for a re-manufactured rack for my zip code.
  6. Jan 11, 2015 at 1:22 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    It sounds like Boch Toyota is doing the work, no?
  7. Jan 11, 2015 at 1:23 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Id tell them you found a dealer who will do the additional parts at a cheaper rate while doing your frame.
  8. Jan 11, 2015 at 1:27 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Probably Boch sucks.
  9. Jan 11, 2015 at 1:30 PM
    File IFR
    Central MA
    As soon as you walk in there, they have their hands jammed deep down into your pockets.. thieves.
    I wanna see Bamma give me shit for that comment. :rolleyes:
  10. Jan 11, 2015 at 1:32 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    But they did just give me a 557.00 check back off my extended warranty they screwed me on.
  11. Jan 11, 2015 at 1:39 PM
    ZSpeed07
    ZSpeed07 Well-Known Member
    Milwaukee, WI
    2007 silver access cab Tacoma Trd off-road
    What a Napa reman rack retails for is not what the shop will pay either... Most shops get it for cost then mark it up to some extent...
  12. Jan 11, 2015 at 2:14 PM
    BTR
    Mass
    06 Tacoma 4x4 v6
    no kidding huh? I dont mind paying for the parts but this is redic.
    not a bad idea, supposedly they HAVE to do the shocks because one "blew up" so I may have them just do those.
    however. can I find toyota parts for a cheaper price and forward them the link?
    IRA
    do they usually lessen the price for saying that?
    I'm going to ask them for the breakdown of parts/labor.
    even with replacing the lines, pump and rack it sounds like it should be less than 1600$
  13. Jan 11, 2015 at 2:19 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    You can order the complete quick strut for $400 for both sides with NO labor to install, since they have to be pulled anyhow to change the frame...It looks to me that they are being very well paid for the add-ons.
    Howard
  14. Jan 11, 2015 at 3:23 PM
    Ryanv
    15 4Runner
    How did a shock "blow up"? hit it with a torch? Shocks don't just blow up, I would be pushing for at minimum you pay cost on parts and they should do the labour free.
  15. Jan 11, 2015 at 5:31 PM
    ZachMX
    It would be worth a shot. Gotta think they are getting paid by toyota to do the frame, your doing them a favor, they should have to earn your business not double dip and be greedy.
  16. Jan 11, 2015 at 7:20 PM
    lyodbraun
    lyodbraun Well-Known Member
    NW Ohio
    2006 SR5 TRD Sport
    Nothing yet
    Dealer makes around 11k to 14k on doing the frame recall, I had all my shocks replaced with billies and they never charged me... Said what ever I wanted to have installed free labor...
  17. Jan 12, 2015 at 3:18 AM
    BTR
    Mass
    06 Tacoma 4x4 v6
    Wow. In that case I'll just tell them to button the truck up and I'll take it somewhere else.
    Anyone know how many hours a steering rack takes? Dealership said it would take around 7 hours and would be an extra 805$ in labor if I didn't do it while the frame was off.
  18. Jan 12, 2015 at 5:58 AM
    fixnfly
    S.W.PA
    Did you notice any problems with the rack before you took it in? What did they say was wrong with it?
  19. Jan 12, 2015 at 6:51 AM
    anotherreject
    anotherreject Well-Known Member
    When my rack needed replaced it was a all day job at a trusted shop
  20. Jan 12, 2015 at 8:15 AM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    Most of what you described has to come off anyways. They should not charge for you any additional labor for anything.
    I would ask to see the shock and see how it "exploded" if its something they did such as put a torch on it or something from disassembly then make them pay for it.
    I just went through the frame replacement, be careful and stick to your guns. and make sure you check the truck out thoroughly once you get it back for shit that isnt right. I brought mine back with a laundry list of things wrong.
    The front struts have to come off, they should not charge you to replace them. The only labor i can see them being able to justify charging is to disassemble the old ones /assemble the new ones. If you were smart find a set of take off's or used onese already assembled in the classifieds here and drop them off. At that point there should be no labor and you can probably get new ones here for ~$100
    With the u joints i can see them charging labor to change them out on the drive shaft but the labor shouldn't be to take the drive shaft in or out. $283 is ridiculous.
    As far as the rack goes it should all be coming off with the frame. charging labor on that is BS. I would pick up your own rack and drop it off. Tell them its coming off anyways and just put the new one in as they go.
    Im glad i didn't go to IRA
