New Frame Protection / Pre-Rust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Arrampico, May 21, 2015.
  1. May 21, 2015 at 3:08 PM
    Arrampico
    Arrampico [OP] Well-Known Member
    Dan
    2018 4Runner SR5
    2017 SR5 Silver DCSB 4x4 V6 (RIP - Traded-in for T4R)
    So I have my brand new Taco and want make the frame as bulletproof as possible. I'm not a mechanic and do not have a garage or lift to do major work.
    Just wondering what the best way to prep my frame for the future.....do I have to sand off everything and do a POR 15 treatment? Can I just clean it off really good and put a coat of some Rustoleum? Is there a special paint I can just paint on top of the new frame? I've read for about 2 hours and haven't found anything about protecting brand new frames - but I'm sure there's a way if I am thinking about it.
    Appreciate any help!
    Thanks,
    Dan
  2. May 21, 2015 at 3:18 PM
    glock24
    glock24 Well-Known Member
    I'm in the same boat as you. I got a 2015, and I don't want to find out the hard way that Toyota hasn't solved the rust problem yet.
    At a minimum, I'm thinking about a treatment of Fluid Film each Fall in preparation for the Michigan winters.
    I think POR-15 is a great idea, and I'm under the impression that stuff will go on right over the current finish on the frame. It'll hold up much better than Rustoleum.
    My dealer tried to sell me a rust treatment. I wonder what they are using on new frames?
  3. May 21, 2015 at 3:20 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  4. May 21, 2015 at 3:26 PM
    Arrampico
    Dan
    2018 4Runner SR5
    thanks Taco - I've seen that. Will take the rest of the year to read all of it....:annoyed:....maybe I just need to get started. I was just hoping somebody with body/frame experience could give me an idea of what I could easily spray on for now to prevent/protect as my frame is still brand new.
  5. May 21, 2015 at 5:05 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I power wash & spray linseed oil once or twice a year. No rust 2008 NJ. Cheap - $40 a gal - us about a qt per
    Arrampico[OP] and patbegley like this.
  6. May 21, 2015 at 6:16 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Sub? Subbed
  7. May 21, 2015 at 6:34 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    FLUID FILM. 2-3 cans will about cover your undercarraige. Do it two times a year. I live in the Midwest where road salt is spread. I have no undercarriage rust yet on my 13.
  8. May 21, 2015 at 6:36 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Rust Cure Formula 3000
    Arrampico[OP] likes this.
  9. May 25, 2015 at 5:11 PM
    Arrampico
    Dan
    2018 4Runner SR5
    Thanks George-I'm going to research linseed. How do you apply, and can linseed touch/go on everything under the taco?
  10. May 25, 2015 at 5:12 PM
    Arrampico
    Dan
    2018 4Runner SR5
    Thanks Oz, I'll check out rust cure.
  11. May 25, 2015 at 5:14 PM
    Arrampico
    Dan
    2018 4Runner SR5
    Reading pretty hood reviews on fluid film, but i really don't want to clean and respray every year. I'm looking for a one time coating to seal/protect.....if it exists.
  12. May 25, 2015 at 5:19 PM
    Arrampico
    Dan
    2018 4Runner SR5
    So my dealer quoted me $299 for Auto Armor ECP. That's what the Toyota dealer is now coating all the frames with. They told me with this they guarantee the frame for seven years, then every three after that i have to re-coat to keep up the guarantee forever...
  13. May 25, 2015 at 5:19 PM
    Arrampico
    Dan
    2018 4Runner SR5
    Thoughts?
  14. May 25, 2015 at 7:29 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Honestly If you have new truck. Simply ..
    Find Valspar Tractor and Implement Primer and Enamel paint.
    Make sure your frame is clean and hit first with primer, than with enamel
    It will last much longer than crappy paint Toyota put on that thing.
    http://www.valsparpaint.com/en/find...ray-paint-1/tractor-and-implement-enamel.html
    It will also last longer than POR-15
    Arrampico[QUOTED][OP] likes this.
  15. May 25, 2015 at 7:33 PM
    patbegley
    The Kootenays
    '22 DCLB
    Have my Krown Rust Protection appointment tomorrow.. Drilling doors and pillars.
  16. May 25, 2015 at 7:40 PM
    Arrampico
    Dan
    2018 4Runner SR5
    Not a krown within 300 miles....
  17. May 25, 2015 at 7:42 PM
    Arrampico
    Dan
    2018 4Runner SR5
    Perfect-this is more what I'm looking to do. Still reading and debating-so many people go with an oil/wax base protectant.
  18. May 25, 2015 at 7:47 PM
    BlueT
    NorthEast
    The problem is that Toyota uses cheap powder painting that is absolute crap... Once you put wax or anything like that paint will not stick to it. So with brand new truck I would try painting it. This paint is cheaper than POR15 so you can pour a gallon inside the frame to protect all the water ways in there.
    If you pour paint inside make sure you have trays setup all underneath or put some cheap tarp to catch over spill.
  19. May 26, 2015 at 3:29 PM
    Arrampico
    Dan
    2018 4Runner SR5
    Well I spoke with Auto Armor ECP on the phone today. They told me if I get my frame coated it will be covered by a lifetime warranty and Auto Armor is Nation Wide! Checkered Flag Toyota in Virginia Beach quoted me $299......
    Lifetime frame warranty on my frame sounds pretty good to me! I don't care if they wipe dog shit on my frame as long as they are giving me a lifetime warranty!
    Sugar Silva likes this.
  20. May 26, 2015 at 3:41 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Lifetime warranty is the way to go for that price. Sounds good. I would still apply some Formula 3000 or Fluid Film every year in case that company goes tits up or finds a loop hole when your frame rots.
