NEW FRAME RECALL XTRA WORK NEEDED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mad Man Marty, Dec 17, 2014.
  1. Dec 17, 2014 at 7:31 AM
    Mad Man Marty
    Mad Man Marty [OP] Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Ok so we all know Toyota is doing frame replacements in several states.
    I was notified last week that my '07 with 50K needs a new frame.
    The theme of this thread is to discuss the additional work required(i have seen new fuel & brake lines listed in other threads),or desired(i.e.,poly body bushings,upper/lower control arms,etc.).
    Please keep the discussion to the additional work you would like or need to have done & not the recall itself.
    Thanks.
  2. Dec 17, 2014 at 8:16 AM
    4myTaco
    4myTaco SmaSh it Up
    Lucas
    Plainfield, IL
    06 DCLB Sport
    OME 3" lift up Front, LR UCA's, All-Pro Expo leafs in back, 17" XD Addicts with 285/70/17s, OEM Roof Rack, Westin Light Bar, Relentless Tailgate plate, Weathertech's, Blue Sea Fuse Box, Iggy's Switch Holder, Pioneer avh-3300bt Radio, LED Interior/License Plate Lights
    The frame replacement includes LCA's and brake lines.
    I am waiting until the spring, but plan on new bushings/ball joins for my UCA's and hopefully coil overs for the front and shocks for the back.
  3. Dec 18, 2014 at 7:22 AM
    Mad Man Marty
    Marty
    PA
    Wow this is totally different from what I was told by the dealer tech last week.
    He told me the only items that are included other than the frame are the bolts that hold the body to the frame.
    Is this incorrect?
  4. Dec 18, 2014 at 7:25 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    When they did my brother in law's last year he got new rear springs, new lower control arms, all new brake/fuel lines, lots of new hardware, and they actually even replaced his lower steering knuckle at no charge too.
  5. Dec 18, 2014 at 8:00 AM
    Supramacy
    Supramacy Well-Known Member
    When we replace a frame the first thing we do is a good tour of the truck to see what should be replaced while disassembled ie. Upper ball joints, intermediate, shaft rack and pinion etc. it is definitely to your advantage to replace the parts that are due because the techs will have them in their hands and you will save on labor.
  6. Dec 18, 2014 at 8:02 AM
    Supramacy
    As far as collateral parts that need to be replaced because they broke while disassembly usually the service manager has to make a report with tas to have permission to replace the part. (I have never had a part that they didn't pay for)
  7. Dec 18, 2014 at 8:55 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    fyi
  8. Dec 31, 2014 at 8:31 AM
    Mad Man Marty
    Marty
    PA
    How about a Energy Suspension master kit?
  9. Jan 1, 2015 at 8:36 AM
    Mad Man Marty
    Marty
    PA
  10. Jan 1, 2015 at 8:54 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    What is this? Aftermarket?
  11. Jan 1, 2015 at 8:57 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    You could request they bring the kit parts to the new install, but you may have to pay a little extra for the bushing swap out...
  12. Jan 1, 2015 at 10:09 AM
    Mad Man Marty
    Marty
    PA
    Lj,yes it is a aftermarket poly bushing kit that includes almost all bushings(body,steering,etc.).
    Bld,yes,although some of the parts(like the body bushings)just need to be inserted before they drop the body back down on the frame.
  13. Jan 4, 2015 at 9:24 AM
    Mad Man Marty
    Marty
    PA
    A member on another thread was discussing the 28 plugs that are included in the frame coating fix.
    Anyone know if they include these for the frame replacement?
  14. Jan 4, 2015 at 9:27 AM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    I "think" the plugs are part of it but I am not sure. I will look on my service write up later today.
  15. Oct 1, 2015 at 7:25 AM
    Mad Man Marty
    Marty
    PA
    So I finally got my truck done a few weeks ago.
    I got it home & it would not crank,& the 4wd did not work.
    Dealer ( freedom Toyota,Harrisburg,pa) fixed everything. Highly recco the dealer.
    Anyway here is the parts they installed;
    Frame
    LCArms & bushings,bolts
    Rear springs & bushings,bolts,new springs next year?
    Brake lines & fluid
    PS fluid
    Front dif actuator & fluid
    Bolts,nuts & fasteners throughout
    Had them install Energy Suspension body bushings,NC.
    $12k in charges.
    Truck drives better than new & tight as hell.
