New From Louisiana/ question about my tires
Discussion in 'New Members' started by Est.1989, Sep 1, 2010.
  1. Sep 1, 2010 at 12:18 PM
    Est.1989
    Est.1989 [OP] Member
    Brandt
    Baton Rouge, Lousiana
    08 PreRunner SR5 4beater
    Tough Country 3" lift, halo foglights, wheel spacers, tint
    I just bought my first tacoma 2 months ago, its a 2.7 manual prerunner sr5.. nothing special. i did just buy a 3" lift that is on its way to me in the mail. i was told that 285 can fit but might run when turned hard. anyone have a 3" lift and 285's? will it work?
    also... should i get a chip or regear?
    thanks
    brandt​
  2. Sep 5, 2010 at 7:27 PM
    AlexXx
    AlexXx Well-Known Member
    Louisiana
    99 taco
    All-Pro 3" Rear kit, Camburg Coilovers, 1" RB BL, 285/75/16's, and rear Lock Right locker Collecting 4wd parts to convert.
    I run a 3" lift plus 1" body lift. I only did the BL, so I didn't have to worry about beating the pinch weld. I also have 285/75/16's and they do rub full lock, just do turn that sharp! haha. But you have a late model taco, so the rubbing should be minimal or not at all.
    On the chip/re-gear q. There's no chip that can help I promise. Now re-gearing is a better solution. What gears do you have now?
  3. Sep 6, 2010 at 5:38 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You might have some rubbing on the cab mount and/or on the plastic around your fender wells. Just take your time when trimming and you'll be fine.
    "Chips" like the ones from ebay don't do much. If you want better performance- Take a look around URDUSA.com for some ideas. And I wouldn't worry about regearing quite yet...but you can if you want.
  4. Oct 4, 2010 at 7:44 AM
    Est.1989
    Brandt
    Ive got stock gears and i put the 285/75/16's on and only rub when i turn the wheel as hard as it can.. i just wont do that
    and thanks brunes, im about to look at that website
    ill have pictures up soon
  5. Oct 4, 2010 at 7:57 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have 3" of lift and 33s, all I did was trim the plastic with a razor knife. I have a slight rub when reversing and cutting the wheel hard.
