New from toytech?
Discussion in 'Suspension' started by CASHORT, Sep 29, 2014.
  1. Sep 29, 2014 at 1:15 AM
    CASHORT
    CASHORT [OP] Well-Known Member
    Cory
    Whidbey Island WA
    2006 Black Sand Pearl TRD Off Road 98k miles
    Custom shovel, axe, fishing pole holders, Lumber Rack
  2. Sep 29, 2014 at 9:01 AM
    CASHORT
    Cory
    Whidbey Island WA
    Gonna go talk to local shop today.
  3. Sep 29, 2014 at 9:02 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  4. Sep 29, 2014 at 9:07 AM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    Something doesn't sound right.... If you can run the stock shocks, the spring weight must be heaver than stock and the springs are NOT longer.
  5. Sep 29, 2014 at 9:26 AM
    CASHORT
    Cory
    Whidbey Island WA
    60k that's what I've looking at or ome. this one sparked my interest though. The spacers are just 1/2 top plates compared to a full spacer lift
    So you think they are stiffer. Im not worried about ride its a truck. But the stiffer coils would make it a harsher ride correct?
  6. Sep 29, 2014 at 9:28 AM
    geekhouse23
    I have the full OME kit on mine; can't speak for the billies, but any aftermarket coil is going to be stiffer than stock. I didn't really notice a difference after it was installed.
  7. Sep 29, 2014 at 9:31 AM
    CASHORT
    Cory
    Whidbey Island WA
    Ok appreciate it. I also messaged toytech in theory this would be a better than a spacer right? Thanks for the help.
  8. Sep 29, 2014 at 9:34 AM
    geekhouse23
  9. Sep 29, 2014 at 9:46 AM
    teamcurtis
    Curtis
    San Diego
    It would be a stiffer set up. But that doesn't mean bad. Less small bump compliant, but also less brake dive and would most likely handle heavier hits better.
    It really depends on the spring and how linear or progressive it is.
    The OME springs are both longer AND have a heavier spring weight, (just not that much heavier)
  10. Sep 29, 2014 at 10:03 AM
    CASHORT
    Cory
    Whidbey Island WA
    Hmm ok thanks guys appreciate the info.
