New front end vibes, any ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brian, Dec 6, 2009.
  1. Dec 6, 2009 at 6:42 PM
    brian
    brian [OP] Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    K well I think I developed a new vibe today. I noticed it at anywhere from 35-50mph, but I didn't have any room to go much faster so I don't know what the freeway will be like. Its not a strong vibe, its only one you would notice if you're a guy like me who knows exactly what his truck sounds and feels like.
    -symptoms: Front end light 'pulsing' vibration. To me its the sound that I got on my old ranger when I left my hubs locked in, but running in 2WD. Its typically on a light acceleration, but I dont remember if it went away when slowing down, I think it did.
    Now.... thinking about my hubs being locked in, I'm on a straight area of road and I pop my 4WD in for a second. Guess what, the vibe went away. Drive it for a few yards, still gone. Pop it out of 4WD, I hear the solenoid under my dash click, I feel my transfer case disengage, and then the second I feel/hear my hubs click out, the vibe comes back.
    Sitting in the shop, I played with the CV's a little bit, theres no real play in the passenger side CV, but the drivers side has that play that everyone questioned for awhile, but it seems really out of specs to me. The CV has alot of play in the front end housing. I'll ask the same thing that many others have before, is this really normal???
    If thats normal, then what is causing my new vibe in 2WD?
  2. Dec 7, 2009 at 10:04 AM
    brian
    Elizabeth City, NC
    anyone?
  3. Dec 7, 2009 at 10:08 AM
    JAG
    JAG Well-Known Member
    I'm getting a similar vibe... its at the dealer today. I'm only 2wd though. It has the techs stumped, but once I get it back or know something I'll let you know. It sounds like my same symptoms... They told me their gonna check my driveline and all the engine mount welds to make sure no breaks or stuff...
  4. Dec 7, 2009 at 10:12 AM
    brian
    Elizabeth City, NC
    haha alright! Thanks! I'd like to believe we'd have to same problem, but I'd doubt it if you're a pre-runner, it feels like a front end issue specifically, and since its when I step on the gas, I'm thinking driveline/CV related. Please let me know either way, I'm typically wrong :)
    Love the sig.
  5. Dec 7, 2009 at 10:12 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The hubs are always "locked". The engagement is done in the front differential. It is possible you have a bearing on it's way south.
  6. Dec 7, 2009 at 10:18 AM
    brian
    Elizabeth City, NC
    Alright, bearing is a good possibility, completely overlooked that. Are the bearings serviceable or is it a complete assembly with the hub? May end up taking it in if thats the case, still have 40k left on warranty :) Assuming bearings are covered....
    But please tell me this, if the hubs are always locked, then why does the noise come about a second AFTER the typical 'clunk' of the transfer case? I hear a click afterwards, and thats when the vibe/noise comes back.
  7. Dec 7, 2009 at 11:06 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Because the front diff is disengaged/engaged via vacuum. The vacuum is engaged via an electric actuator. There is a delay to the whole sequence.
  8. Dec 7, 2009 at 11:12 AM
    brian
    Elizabeth City, NC
    Ok I think I get it.... solenoid kicks in, allows vacuum, once ECU senes diff out, solenoid kicks out..... essentially, click CLUNK click.
  9. Dec 7, 2009 at 11:15 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  10. Dec 7, 2009 at 11:35 AM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
  11. Dec 7, 2009 at 11:51 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
  12. Dec 7, 2009 at 11:54 AM
    prae
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    me too. Lifted w/ 5100's and eibach coils, AAL in the rear. Didn't notice any vibes for the first 50 miles, then I got it aligned and put a diff drop in. Have had the vibe that goes away in 4wd ever since.
    You running a diff drop or not?
    I am planning on rotating my tires (to account for possible uneven wear prior to alignment), checking my wheel bearings for play, checking my cv shafts for play, and then possibly speaking with the dealer to see if they can diagnose the issue.
  13. Dec 8, 2009 at 11:45 AM
    TRD4x4
    TRD4x4 New Member
    Jeff
    Vancouver
    07 TRD dbl cab 4x4
    cold air intake
    Mine is at the dealer today, they're replacing the front diff. Glad it is still under warranty!
  14. Dec 8, 2009 at 11:47 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Welcome to TW
    Did you have the same symptoms?
  15. Dec 8, 2009 at 12:14 PM
    TRD4x4
    TRD4x4 New Member
    Jeff
    Vancouver
    07 TRD dbl cab 4x4
    cold air intake
    I did. I found it happened between about 25 and 40 mph. Just got off the phone from the dealer who just finished the work, I asked if they have upgraded the diff or is it still the same. He said they haven't made any changes so I'm thinking I might be doing this again after another 40,000 miles.
  16. Dec 10, 2009 at 4:50 PM
    brian
    Elizabeth City, NC
    Okay, whatever this issue is... I managed to get it to go away tonight. It originally started right after I kicked in the 4WD for a little 'warmup' since I hadn't used it all summer.
    Tonight after getting frustrated with it, I played with the 4WD in and out a few more times, third time was a charm because the noise/vibe finally didn't come back. Afraid to throw it back in 4WD for now until I figure out what it is.... sounds like something is out of adjustment.
    EDIT: btw I do have the diff drop spacer.
    I just read the TN thread a little... seems like I might be able to get the dealer to fix, I would think after being in a few times in the past year they might be getting annoyed by me though. Especially when you consider the lift.
  17. Dec 10, 2009 at 5:08 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    The front wheel bearing is servicable.the stealership sells them at around $150. it isn't pressed into the knuckle but i think it is pressed into the splined hub
  18. Dec 10, 2009 at 5:21 PM
    brian
    Elizabeth City, NC
    Def not a wheel bearing though now.
  19. Dec 11, 2009 at 5:30 PM
    TRD4x4
    TRD4x4 New Member
    Jeff
    Vancouver
    07 TRD dbl cab 4x4
    cold air intake
    Well I've had the truck back for a few days now, there is a shiny new diff under there and no vibration. Still worried that this is a band-aid solution. I know that they have been using the same front end for years now and can't understand why there is a problem all of a sudden.
    As a side note I put on a TRD cai today and I'm not sure if it has added any power but it does sound good!
  20. Dec 11, 2009 at 5:33 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I don't think it's a band aid solution. By the sounds of the many reports of owners with this issue, I am thinking the diff manufacturer got a hold of a bad batch of bearings.
