new front rims rub brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by mattharvey44, Nov 2, 2013.
  1. Nov 2, 2013 at 9:11 PM
    mattharvey44
    mattharvey44 [OP] New Member
    11 ext cab 5 lug sr5
    Tires, rims, exhaust, k&n, stereo, lift coming soon
    My new front rims rub my brakes without spacers but the rims are deep dish so they stick out without spacers I don't want my tires to stick out too far and the rims were free any ideas on what I can do and pics would ve appreciated
  2. Nov 2, 2013 at 11:09 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Replace those junk rims (you get what you pay for), and replace them with ones that actually fit.
  3. Nov 2, 2013 at 11:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you really a 2nd gen 5 lug?
    You will likely get better feedback if you post your question in the 2nd gen section.
  4. Nov 3, 2013 at 12:12 AM
    gearcruncher
    Canadain bumper technician
    I see vibration problems with those rims as well . Anytime the backspacing is changed , the wheel is moved away from the rotor changing the original geometry of the front end .
    If the wheel sticks out past the fender you put a high stress factor on the front end components .A set of wider fender flares will help your paint .
    Best bet is to sell the rims.
  5. Nov 3, 2013 at 5:24 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Need to know which rims you got. If they're only rubbing slightly (like most steel 'D-window' rims with low back-spacking do) you can grind the caliper to allow clearance. Look up that mod. But first, take pictures and post them.
  6. Nov 3, 2013 at 7:07 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  7. Nov 3, 2013 at 7:43 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Aftermarket wheels are usually reversed barrels which means the center of the barrel hangs down lower and are notorious for hitting Tacoma calipers. If its a Gen2 truck then you usually need to go with at least a 17" to clear the calipers or find yourself a non reversed barrel which is really hard to find in an aftermarket wheel. We need more info, you need to tell us what you have? Which diameter, what width, the offset; year of your Tacoma, etc.
