new frontend - now knocking noise on sharp turn
Discussion in '1st Gen. Tacomas (1995-2004)' started by idriveatacoma, Oct 13, 2011.
  1. Oct 13, 2011 at 7:09 PM
    idriveatacoma
    idriveatacoma [OP] Member
    I just had shocks, struts, steering rack, and outer tie rods replaced. Backing out of a parking spot today, so basically a Sharp right turn going backwards, and I hear a pop. Everything looks good, no leaks and I can make it happen again. Any ideas? I don't think I'm getting tie rod contact or anything. Everything is stock.
  2. Oct 13, 2011 at 7:36 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    ball joints?
  3. Oct 13, 2011 at 7:52 PM
    idriveatacoma
    Think so? Never had this issue before I had this work done
  4. Oct 13, 2011 at 8:04 PM
    TacoMX
    Jonathan
    Deltona, Florida
    are the bj's original? How many miles on the truck? What kind (brand) of parts were used when you had the work done?
  5. Oct 13, 2011 at 8:08 PM
    idriveatacoma
    Probably original ball joints. 02 4wd. Parts should all be oem except rack bushings which are energy suspension
  6. Oct 13, 2011 at 8:09 PM
    idriveatacoma
    160,000 miles
  7. Oct 13, 2011 at 8:09 PM
    TacoMX
    Jonathan
    Deltona, Florida
    does it do it when turning the wheel or when you are moving only?
  8. Oct 13, 2011 at 8:12 PM
    idriveatacoma
    Just when moving - at a sharp turn like pulling in a parking spot real slow. I did notice the pump seems to work a little harder at max turn now but probly besides the point. This work was done yesterday
  9. Oct 13, 2011 at 8:16 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I would take the truck back to where you had the work done and ask them about it. Are they a good shop you know?
    Check your power-steering fluid level too.
  10. Oct 13, 2011 at 8:18 PM
    idriveatacoma
    First time at this shop bit seems pretty good. I'll do that. Thanks for the advice
  11. Oct 14, 2011 at 11:30 AM
    idriveatacoma
    i think the tie rod ends are on backwards and hit the wheel - which way should they curve? in towards the back of the truck, out towards the front of the truck?
  12. Oct 14, 2011 at 11:34 AM
    TacoMX
    Jonathan
    Deltona, Florida
    toward the front if I understand you correctly
    Take a pic and post it up
  13. Oct 14, 2011 at 1:55 PM
    idriveatacoma
