New fuel door, what type of clearcoat?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegrandpoohbah, Aug 21, 2020.
  1. Aug 21, 2020 at 11:35 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Just suffered the apparently very common broken fuel door hinge. I have the new door from my local dealership and got my hands on a can of 4T3 to spray it myself. Question is, what is the best clearcoat to use for this? And do I want glossy or matte?
    wags likes this.
  2. Aug 22, 2020 at 3:23 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You could just change the hinge and keep the original painted door. That's what I did.
  3. Aug 22, 2020 at 3:28 AM
    Tacoma Angler
    Tacoma Angler Member
    2020 Trd off-road
    Can you tell me where you ordered the hinge from, my dealer told me it was one complete unit. Thanks
    BizzyB726 likes this.
  4. Aug 22, 2020 at 4:19 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    I don't believe you can buy a hinge only then attach your correct color fuel door since it comes as a complete unit. I had a local body shop paint and mount mine for around $100. They did a fantastic job! Keep those hinges lubricated!!
  5. Aug 22, 2020 at 8:57 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
  6. Aug 22, 2020 at 4:59 PM
    thegrandpoohbah
    Terrace, BC, Canada
  7. Aug 22, 2020 at 5:14 PM
    mikkydee
    Doyle
    Florida
    If that is what you are using for a clear coat It may be ok but if it were mine I would use a 2K catalyzed clear like the one on the rest of your truck.
    vssman likes this.
  8. Aug 23, 2020 at 4:57 AM
    fixnfly
    S.W.PA
    Dealership. Or a salvage yard if your lucky enough to find a tacoma in one.
    The double cab door is different from the access cab/ regular cab door. The hinge and door come as an assembly unpainted from the dealer.
    I just carefully pried the hinge tabs open on the new door with a flat screwdriver, removed the new hinge and reinstalled on my original door. Just don't bend the tabs open any more than you need to. I used 1/4" bolts nuts and washers to reinstall the hinge and door on the truck. I originally bought the oem rivets that hold the hinge on but the shanks are huge and require a special tool other than a standard parts store rivet puller. A new door and hinge from the dealership is around $40.
  9. Aug 23, 2020 at 6:30 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    @mikkydee is right on. If you’re going to paint, 2K clear is the only way to go and Spraymax is a great brand for spot repairs.
