New fuel pump, intermittent non start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deepseeman, Mar 4, 2020.
  1. Mar 4, 2020 at 12:49 PM
    Deepseeman
    Deepseeman [OP] Member
    Eddie
    San Diego, CA
    looking
    Hey all,
    I just replaced my 2012 fuel pump assy last Friday as the gas gauge sending unit wasn't working. Now, every now and again she wont start. It happened once on Sunday, yesterday and today. Two of which times my GF had the truck. The first two times I crawled under and pressed on the plug to the pump and it started. I feel that was just coincidence. Today my GF was stuck at a gas station and it wouldn't start. she waited 15-20 minutes and it started. What do you think it could be? faulty pump (Delphi)? bad connection?
  2. Mar 8, 2020 at 10:36 PM
    Deepseeman
    Eddie
    San Diego, CA
    looking
    well, its happened twice since this post. i dropped the tank again and everything appears to be fine. still no suggestions? might just drop the tank and replace the pump again since its a lifetime warranty.
    Thuguon2.7 likes this.
  3. Mar 8, 2020 at 10:50 PM
    Thuguon2.7
    Thuguon2.7 Cheeehuuu
    J
    SoCal.
    ‘15 1GRFESR5AC
    BUMP!
    Sorry I can’t help bro.
    But..
    Is the plug terminal dirty?
    Are ur battery cables loose?
  4. Mar 9, 2020 at 7:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    when it doenst start does it just crank n crank n crank? have you tried turning the key to run, to prime the system, turning it back off, then back to run to prime again before trying to start when this occurs?
  5. Mar 9, 2020 at 11:49 AM
    Deepseeman
    Eddie
    San Diego, CA
    looking
    yep, cranks like its out of gas. It seems that its losing prime, but it shouldn't be. All lines are tight and electrical connections are sound. Battery is fresh.
  6. Mar 9, 2020 at 11:52 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    bad charcoal cannister
  7. Mar 9, 2020 at 12:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Delphi replacement?
    I have ordered new replacement parts that were that specific brand, which failed very shortly after start-up. May or may not be something to consider.
  8. Mar 9, 2020 at 12:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could be something with the connector itself, on the new part's side. Loose connection perhaps.
  9. Mar 9, 2020 at 1:59 PM
    nd4spdbh
    SoCal
    does it just never start unless you fiddle with stuff at the tank?
