New garage
Discussion in 'Garage / Workshop' started by Przemekmsu, Apr 22, 2012.
  1. Apr 30, 2012 at 4:42 PM
    #41
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    And so aliens don't lift your roof off.
  2. Apr 30, 2012 at 4:50 PM
    #42
    Larry
    Larry CARL
    CARL
    correct.
  3. Apr 30, 2012 at 4:51 PM
    #43
    Larry
    Larry CARL
    CARL
    yes
    aliens with names like Opal. Erin. Ivan. Andrew. Katrina. Dennis. Hugo. etc. :D
  4. Apr 30, 2012 at 4:52 PM
    #44
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How do you handle building settling / shrinkage with regards to the redi-rod ? Tighten them again just prior to insulation / wallboard ?
  5. Apr 30, 2012 at 5:03 PM
    #45
    Larry
    Larry CARL
    CARL
    there really is no "settling". however, there is some shrinkage to the frame walls, but not enough to matter. I have tightened them up a little if one seems excessively loose.
    here is the gig: 12" x 5/8" galv. J bolt placed in the slab during pour (8-10" embedement)...a 1/4" x 2"x2" sq galv. washer & nut bolts the sill plate to the slab...a galv. coupling connected to the remaining bolt stub...a length of 5/8" galv. all-thread rod through the double top plates...w/ another sq washer and nut.
    so, even if it was a little loose...it still does its intended job.
    keep in mind, there are also SP1 & SP2 clips on studs...straps on openings...and 1/2" plywood tying it all together.
    I actually believe the plywood does more than all the steel, to hold the wall together. But, I'm a big believer of "saddle" truss hold downs....that, is the weak spot on most buildings.
  6. Apr 30, 2012 at 5:09 PM
    #46
    OZ-T
    Peter North
    British Columbia
    Agreed
    The plywood is a huge factor
    We have similar connection details but for lateral restraint and seismic loading
  7. May 26, 2012 at 4:46 PM
    #47
    Larry
    Larry CARL
    CARL
    some shop progress:
    guest cottage:
