New gaskets with DTLH install?
Discussion in 'Performance and Tuning' started by LouTaco, Sep 28, 2011.
  1. Sep 28, 2011 at 7:08 PM
    LouTaco
    LouTaco [OP] Well-Known Member
    Lou
    Des Moines, Iowa
    2010 MGM DCSB TRD Sport 4x4
    5100's, OME 885X coils, Top plate spacer kit, TC UCA, TSB Leaf pack w/ 1.5" TSB AAL and 1/2" block, Weathertechs, BHLM w/ Retrofit, Foglight Mod, Illuminated 4x4 switch, 18" Wicked Flow, AP U-bolt flip kit, DTLH w/ URD O2 sim, SCS Stealth 6 wheels, 285/70/17 TG G2, ImMrYo bracket
    I read that using the old OEM manifold gaskets is ok, but is it ok to reuse the gasket from the header to y-pipe? What size is the gasket I use if I need a new one? any input would be great thanx
  2. Sep 28, 2011 at 7:28 PM
    LouTaco
    Lou
    Des Moines, Iowa
  3. Sep 29, 2011 at 4:47 PM
    gneitzke
    gneitzke Member
    Seattle
    2006 TRD Offroad 4x4
    I installed new crush washers from URD and used the stock gaskets from my old headers for the manifold. I have had the headers on for about a month and retorqued the headers->y pipe connections over the past week, there is no leaks in my system
  4. Oct 3, 2011 at 3:13 PM
    LouTaco
    Lou
    Des Moines, Iowa
    for header to y- pipe connection everyone says use the URD gasket i dont want to wait for it to come in the mail. will an OEM gasket from parts store work with the DTLH?
  5. Oct 3, 2011 at 4:40 PM
    gneitzke
    gneitzke Member
    Seattle
    I suppose it will work if it is the correct thickeness/diameter. With URD you can just use Priority mail from URD and it should be there pretty quickly (2-3 days).. I would imagine it would be closer to two days since it ships from the east coast.
