New Gear Hunting World Record 2024
Discussion in '3rd Gen. Tacomas (2016-2023)' started by assist, Oct 14, 2024.
  1. Oct 14, 2024 at 3:05 PM
    assist
    assist [OP] Roadside Assistance
    New Hampshire
    2022 Silver TRD S 4X4
    8 shifts within 20 seconds last night. New record? :101010:
    Seriously though, has this repeated hunting happened to anyone else? Would have expected the OTT tune to fix it...
    PARAMETERS:
    3rd Gen Tacoma - Automatic transmission - Overland Torque Tune - Cruise control set to 78mph - S5 mode - Steady grade - No input from driver - 265/70R17 Tires - Hauling no more than 200 pounds of gear at time of filming
    cthoma70 and vivid02 like this.
  2. Oct 14, 2024 at 3:07 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Congratulations
  3. Oct 14, 2024 at 3:28 PM
    eurowner
    eurowner Duke Sky
    Scoty
    You are very lucky you do not have an 8 or 10 speed automatic!
    Chew and kahanabob like this.
  4. Oct 14, 2024 at 3:36 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    I've been thinking about the OTT tune, but not now. Probably need a pedal commander or gen 1,2, or 4 to remedy things. 5th gen will be the best gen.
  5. Oct 14, 2024 at 3:39 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Guess Toyota thinks you should be going 77 instead
    assist[QUOTED][OP] likes this.
  6. Oct 14, 2024 at 3:40 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Manual transmission ought to fix that right up.
  7. Oct 14, 2024 at 3:45 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    That's what happens when you put a double OD 6AT in a truck with economy gearing. A tune won't fix it unless you force it to hold gears longer before upshifting.
  8. Oct 14, 2024 at 3:50 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Simply moving the automatic stick shifter into sport mode and selecting the gear can resolve it. No need to buy a different truck.
  9. Oct 14, 2024 at 3:51 PM
    assist
    New Hampshire
    Yeah guess I'm going to need a regear eventually lol :frusty:
  10. Oct 14, 2024 at 3:51 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    This is exactly why I’m considering a re-gear. My truck is tuned as well (not OTT though) and going up a grade at anything above 75mph, with cruise control on, the truck holds at around 5,000rpm just to keep up to speed. Sometimes 5,500rpm.
    The stock gearing is just garbage. It’s the only thing I dislike about my truck, everything else I absolutely love and I wouldn’t trade this truck for any other vehicle.
    Shellshock likes this.
  11. Oct 14, 2024 at 4:04 PM
    Findus11
    Findus11 Well-Known Member
    Durango
    07 Taco
    You should sell it. Why would you drive a truck that makes you unhappy?
    musicisevil, crazysccrmd and Chew like this.
  12. Oct 14, 2024 at 4:11 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  13. Oct 14, 2024 at 4:13 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    These are the two reasons
    - The shift tables for cruise control are separate from manual driving. Tunes have very limited influence on gear hunting under cruise control. If you repeated the same conditions with cruise control off, it likely wouldn't have hunted.
    - S5 is still overdrive, this would be like top gear for 2nd gen automatics. Slap it into S4 for long grades.
  14. Oct 14, 2024 at 4:19 PM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Have you heard of 5.29 gears
  15. Oct 14, 2024 at 4:27 PM
    assist
    New Hampshire
    Where did you read that the truck is making me unhappy? o_O Going to regear probably and continue to enjoy it
    Helpful info, thanks guys. I was in S5 during this clip and moved it down to S4 for grades afterwards. I typically never use cruise control but this was a 2.5h hour highway drive
  16. Oct 14, 2024 at 5:59 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
  17. Oct 14, 2024 at 6:07 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Did you even read the post I linked?
    fellow_expert and musicisevil like this.
  18. Oct 14, 2024 at 6:09 PM
    Technique
    Alex
    Utah
    Nope LOL.
  19. Oct 14, 2024 at 6:24 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    I just tied your record on the trip I'm on now. 8 shifts from between 5th and 4th in a short time. I was going 67mph up a slight incline where I knew it couldn't hold 5th, so it made no sense for it to upshift. This is with cruise control on.
    And at other times cruise control holds 4th gear after climbing and cresting a hill for 10+ second after it levels off.
    Road_Warrior likes this.
  20. Oct 14, 2024 at 7:07 PM
    Load_Elevation_Fail
    Load_Elevation_Fail Well-Known Member
    Rob
    Oklahoma
    2021 Tacoma TRD OR
    5.29 Gears 3” RC Vetrex Coilovers RC Speedo Calibrator Borla Exhaust OTT Tune 33” KO2s TRD Rims K&N 1.5” Spacers Clazzios Ultra White Interior LEDs Garmin Mini 2 Wide Cup Holders Cali Raised Blue Tint Wide View Mirrors Cat Shields Tailgate Lock Bed Mat Lexus Front Diff Drain Plug RAV4 Stereo Knobs Toyota Metal Oil Filter Housing
    Driving the rolling hills in Oklahoma, I had similar issues. OTT and 5.29s fixed everything for me. Let’s you drive with the cruise and it rarely drops to 5th on the highway now.
    I’m stationed in Oklahoma, it’s not as flat as I expected it to be.
    atc250r likes this.
