New gear ratios
Discussion in 'Technical Chat' started by smmarine, Jan 12, 2016.
  1. Jan 12, 2016 at 4:21 PM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I got a 99 Tacoma, 4cyl automatic. The door code reads 4.10 gears and I'm running 31s. Considering doing gears cause I'll be in the rear end but not sure if I should go up to 4.56 or 4.88. May eventually run a 32" tire
  2. Jan 12, 2016 at 6:32 PM
    smmarine
    Melbourne FL
    Even with an extended cab 2.7 auto?
  3. Jan 12, 2016 at 9:22 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    go to the gear ratio calculator. And if you wheel I'd make sure you over a tad overgeared from stock
  4. Jan 15, 2016 at 9:57 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    are you positive you have 4.10s? My 99 2.7L auto came with 4.56s. If it came stock with 31s there is a good chance you already have 4.56s.
  5. Jan 15, 2016 at 4:35 PM
    smmarine
    Melbourne FL
    The door sticker shows 4.10, and it also shows it came with 225 tires
