New gears. Weird sound.
Discussion in 'Performance and Tuning' started by dvd0020, Apr 28, 2012.
  1. Apr 28, 2012 at 12:55 PM
    dvd0020
    dvd0020 [OP] Well-Known Member
    Dave
    Colorado Springs
    08 Off Road Double Cab
    TRD supercharger, 4.88 Nitro gears, Doug Thorley long tube headers, aFe stage II intake, Pro Comp 6" DB lift (Icon Coilovers, Alcan 6" Springs, Bilstein RCD rears), NST lightweight pulleys, Morimoto mini projector retrofit for Spyder headlights, Cobra CB, 4' Fire stick, Pioneer AVIC-U310BT head unit, 2 10" alpine S, CBI Moab 2.0 front bumper, Smittybilt XRC8 winch, NFAB tire carrier, custom Colorado pinstripes
    So a couple weeks ago I got some new 4.88 Yukon gears installed for my 35" tires. I can hear the gears making low whining noise when I let off the gas. Also does it constantly at around 1100 rpms. Just wanted to make sure this is normal. Doesn't really bother me as long as something isn't wrong. Thanks.
  2. Apr 28, 2012 at 1:03 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Depends on how loud it is.
    New aftermarket gears are built for strength not OEM level quiet. So there may be a little more gear noise. If you had them professionally installed, there'll be a disclaimer on your receipt to that effect.
    That said, if the backlash is set poorly, the gears will be too noisy and will also wear out too quickly.
    I'd say if you're struggling to hear it over the tires (is that tire noise? or the new gears??) it's probably OK. If it's real noticeable, I'd take it back to the shop and at least have them go for a ride with you and listen to it.
  3. Apr 29, 2012 at 10:05 AM
    dvd0020
    Dave
    Colorado Springs
    Thanks for the reply. It is definitely noticeable over the sound of the tires. I will definitely take the truck back to the shop to have them listen. Thanks again!
