New Gen 1 SR5 owner, what should I get done?
Discussion in '1st Gen. Tacomas (1995-2004)' started by The Noid, Sep 10, 2022.
  1. Sep 10, 2022 at 4:31 PM
    The Noid
    The Noid [OP] Member
    1999 SR5 4WD with about 110K miles. The seller only had it for about a year and didn't sound like he did much. What should I get done right off the bat? This is what I was thinking:
    • Change oil
    • Change air filter
    • Change transmission fluid
    • Replace timing belt
    • Add OEM coolant (overfill tank is low)
    What else are "must do" for a car of this age/mileage with an unknown maintenance history?
  2. Sep 10, 2022 at 5:00 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    There are many threads covering this topic, so a little searching and reading should be in your future.
    But the primary considerations are going to be the Lower Ball Joints (LBJs). They are a known weak part, and if you don't know when they were last replaced, or what brand of part they were replaced with, then it's the safe move to replace them with OEM ball joints.
    RE the coolant- Unless you are sure there is Toyota coolant then you should consider a flush. Also, if you're considering the timing belt, also consider the water pump and thermostat- and then the coolant flush.
    In order of importance, the LBJs are the top priority.
    At 110k the timing belt isn't high up there as if it was done, it should have been around 70k. Check the timing belt cover- sometimes the shop will leave a sticker.
    As for the transmission- do your research there. I'd suggest a few drain and fills spaced out over a few hundred or thousand mile intervals.
    There is a member here (and on other toyota forums) who has a great you tube channel: https://www.youtube.com/channel/UC9EMiD9KPy61kJ6hdXcbjxA Hes created a ton of excellent videos which detail out many of the standard maintenience items. Additionally, another member here also has tons of equally great write ups on his site: https://adventuretaco.com/
    Welcome to TW.
  3. Sep 10, 2022 at 6:44 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Full service. Change all fluids. 3.4 V6? If so timing belt, water pump need replacement.
  4. Sep 10, 2022 at 6:46 PM
    The Noid
    Thank you for the replies. I tried searching but couldn't get the right keywords. This being my first 4WD, is there anything I should do for that system?
  5. Sep 10, 2022 at 6:55 PM
    jrallan26
    Iowa
    Invest in a service manual.
  6. Sep 10, 2022 at 8:04 PM
    My1Yoda
    My1Yoda Well-Known Member
    Alex
    2022 Lunar Rock Tacoma TRD OR
    Change the spark plugs.
    MNMLST likes this.
  7. Sep 10, 2022 at 8:30 PM
    Taco1997
    Taco1997 Well-Known Member
    SoCal
    2001 Tacoma prerunner, 2024 Tacoma TRD Offroad
    Wouldn’t be a bad time to check ball joints
  8. Sep 10, 2022 at 9:03 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Brake fluid
    Spark plugs
    Spark wires
    Diff fluid
    Lower ball joints
    Brake pads
    Power steering fluid
    Flush Coolant
    Hamer95USA and Kevins60 like this.
  9. Sep 10, 2022 at 9:09 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Fuel Filter
    Nessal likes this.
  10. Sep 10, 2022 at 9:11 PM
    MNMLST
    Earth
    …operate it somewhat regularly - 4Hi,4Lo,Diff Lock
    Nessal likes this.
  11. Sep 11, 2022 at 7:48 AM
    The Noid
    I4 2.7L. But these items should still apply right?
  12. Sep 11, 2022 at 8:09 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Nope- 2.4 and 2.7 have a timing chain - no belt. There are some I4 suggested items as well- I believe adjusting the valves.
    You can find an online copy of the FSM, I wouldn't suggest investing in a paper copy of the manual. "1st gen FSM pdf" should do the trick.
    The Noid[QUOTED][OP] likes this.
  13. Sep 11, 2022 at 8:17 AM
    jrallan26
    Iowa
    no timing belt but water pump still applies.
  14. Sep 11, 2022 at 10:23 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    + Clean the MAF
    Nessal[QUOTED] likes this.
  15. Sep 11, 2022 at 10:34 AM
    The Noid
    Got it, thanks!
