new girl needs winter advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Truck Chick, Nov 2, 2012.
  1. Nov 7, 2012 at 6:05 AM
    #61
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I haven't noticed it doing anything to my paint. I've been running that stuff for a few years now. As long as you keep up on washing it and the occassional wax job, it shouldn't do anything to the paint job.
  2. Nov 7, 2012 at 6:28 AM
    #62
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I've used it for 4 years now and no ill effects.
  3. Nov 7, 2012 at 6:28 AM
    #63
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    But in all honesty.... I ensure my washer fluid is the low temp kind, I've never changed my antifreeze, and this year I am wanting to spray some Fluid Film on the frame rails etc. to help protect from road salt-I found it at my local John Deere dealership. I couldn't find anywhere else that had it it.
  4. Nov 7, 2012 at 6:46 AM
    #64
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    This stuff.
    Best I've ever used out of a jug, period. Excellent performance, even during ice rain. Protects down to -32C (-25F), which should be plenty for NE.
    In the worst of icing conditions, you can also add extra de-icer to this or standard windshield washer fluid - sold in the same area of the auto department as the washer fluid.
    Cheers,
    Marc
  5. Nov 7, 2012 at 7:34 AM
    #65
    Truck Chick
    Truck Chick [OP] Active Member
    Lauren
    California
    '13 Tacoma
    Thanks again guys! I am also looking at emergency road kits, but I don't want to get one with a bunch of crap I don't need. Any recommendations? Or should I just make my own?
  6. Nov 7, 2012 at 7:39 AM
    #66
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    gun and pepper spray:eek:
  7. Nov 7, 2012 at 7:43 AM
    #67
    Pugga
    Massachusetts
    Make your own. That way you know what's in there and how to use it.
  8. Nov 7, 2012 at 8:23 AM
    #68
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Are you saying they remix the premix? Because I thought you are not suppose to mix anything with the premix?
    Any anyway doesn't the optimal mix protect the best for both freeze and heat?
  9. Nov 7, 2012 at 8:44 AM
    #69
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I just go by the conditions you are going to be in.
    Keep stuff in the truck for city problems and a few containers for when you go out and can toss in the bed.
    If you never go off road then simple city stuff.
    jumper cables
    tow strap
    If you go off road with friends
    water/food for 2 days
    tow strap
    jump cable
    come along
    chain
    blanket
    if you go off road hours from any citys
    water/food for 7 days
    matches/lighter
    blanket
    emergency blanket
    flairs
    air flairs
    gloves
    hats
    extra clothing
    chain
    tow straps
    extra fuel
    engine belt
    brake fluid
    power steer fluid
    antifreeze
    oil
    tools
    tire plug kit
    emergency batt pak
    air compressor
    epoxy paste
    gasket sealant
    radiator sealant
    I basically have stuff in my truck that I will be good for 24 hours no matter winter/summer.
    Then I have some rubbermaid containers with stuff for when I go out to BFE. Enough to fix anything from a broken belt, flat tire to a radiator leak.
  10. Nov 7, 2012 at 12:29 PM
    #70
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
  11. Nov 10, 2012 at 8:19 AM
    #71
    BamaToy1997
    Bill
    Navarre, FL
    Whenever making a safety kit, or an off-road kit, I go by the policy of "Better to have it and not need it, than need it and not have it!"
    I can't quote for dealerships that I haven't worked at, but every dealership that I have worked at did not use premixed coolant. We got 100% coolant in jugs and then mixed them based on what was needed. I have never ran into premixed in a dealership, but I won't say that nobody does, since I haven't worked at every dealership...lol. The optimal mix is based on location. (Another reason supporting a dealership NOT having premixed coolant)
  12. Nov 11, 2012 at 7:34 AM
    #72
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    With all of the comments like this on this thread just shows what pigs most guys really are.
    Try giving a real answer instead of this dickhattery.
  13. Nov 11, 2012 at 8:22 AM
    #73
    fjrmurph
    fjrmurph Well-Known Member
    hi there
    Welcome
    your anti-freeze should be fine, most service shops will have an anti-freeze tester, they will test and make sure it is strong enough so that it won't freeze in your engine this winter
    emergency kit >> warm clothes,hats gloves scarf
    >>flashlight and some spare batteries
    >> candle, if your broke down or stuck in a snowbank a candle
    won't keep ya toasty warm but it will create a lot of heat
    in a small truck cab
    >> tow rope/chain
    >> cell and cell charger
    If you were to get stuck in a storm and you are running your truck engine to keep warm always be mindfull of wind direction and your exhaust, be carefull of carbon monoxide piosoning. Always keep lots of gas in the tank, in the winter i consider 1/2 a tank as my empty mark.
    Drive safe, get used the increased stopping distance we all need in the winter, practice emergency stops on a side road/parking lot to get a feel on how the truck is going to react.
  14. Nov 9, 2013 at 2:47 AM
    #74
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    all we ever do to winterize a truck is check the coolant the cca s on the battery and the washer fluid.basically make sure your freeze point of your coolant is good your cold cranking amps are ok and nothings gonna freeze and crack some metal, if you like you can use a thinner oil so cranking is easier but Ive never had a problem with 10-40 or 5-40 synthetic mobil one . the most important one is your you need to test coolant with either a refracometer or test strips
    if it freezes in your engine it will either crack your block or your head although once i had it just ruin a gasket.
