New gun FTE
Discussion in 'Guns & Hunting' started by mash25, Nov 22, 2012.
  1. Nov 22, 2012 at 1:28 PM
    mash25
    mash25 [OP] Roll Tide Roll
    Mark
    Bama
    '08 DC Sport 4X4..
    TGC 3'' lift,18'' Addicts,33'' Trail Grapplers
    Hey all I'm new here and am in need of help...I'm new to the ar world but not to weapons in general...so I picked up a DPMS oracle last night for 595 and started shooting it this morning...first 2 mags shot flawlessly next mag is where it started...it'll load and fire the first round then when it extracts it never lets go of the round it comes back and then tries to load another round and still never ejected so now it's double loading...I've done a complete field strip and cleaned everything put it together and same thing again..this has pissed me off beyond belief not even 50 rds thru it yet...any suggestions???
  2. Nov 22, 2012 at 1:32 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    What have you lubed the gun with?
  3. Nov 22, 2012 at 1:36 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    maybe a problem with the ammunition? My father had a problem with his 45acp one time not ejecting turns out the ammunition we were loading for it didnt quite have enough powder charge
  4. Nov 22, 2012 at 1:37 PM
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Hoppes and militec
  5. Nov 22, 2012 at 1:37 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Have you tried different types of rounds?
    Buy a box of Federal 5.56, that's what I shoot through my AR15.
  6. Nov 22, 2012 at 1:38 PM
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Ive tried hornady and federal ammo
  7. Nov 22, 2012 at 1:40 PM
    krimson
    krimson Nothin
    TRD Off Road
    Contact DPMS, your rifle should be under warranty.
    I looked up your rifle and it seems to be A common problem with the rifle not ejecting rounds correctly.
  8. Nov 22, 2012 at 1:41 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Sounds like a defective bolt carrier group. Call dpms and they'll take care of you.
  9. Nov 22, 2012 at 1:46 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ammo should be good.
    Buffer and spring weight? Gas system length? Barrel length?
    When the brass does extract properly, where does it land? 2:00? 3:00? 5:00?
  10. Nov 22, 2012 at 1:50 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Take it back and get an LMT
    Or call DPMS like it was said earlier, should still be under warranty
  11. Nov 22, 2012 at 1:57 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    This. Something with the ejector is screwy.
    Have you stripped the BCG and pulled the extractor off to see if there is something wrong with it?
  12. Nov 22, 2012 at 2:08 PM
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    The bolt carrier never releases the empty shell it just stays in there and the goes forward to try and load another round....yes I completely disassembled everything and all looks to be good
  13. Nov 22, 2012 at 2:21 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    Also, double check that you didn't put the bolt back in the bolt carrier rotated 180 degrees. I just talked to someone that saw a dpms from the factory with the bolt backwards so the rounds were ejecting to the left "away from the ejection port"
    IF your empty brass is getting stuck in the chamber that could be over lubing if it is dripping with lube. Or, could just be not enough lube on the outside of the bolt carrier.
    Good luck
  14. Nov 22, 2012 at 2:23 PM
    ffemt2987
    Austin
    Golden
    So can you 1) load a round ...2)drop the mag... 3) rack the charging handle and eject that chambered round?
  15. Nov 22, 2012 at 2:31 PM
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    No...I can load a round...drop the mag...rack it and round never ejects
  16. Nov 22, 2012 at 2:35 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    CHeck the grains on the rounds, they may not have enough. Call dpms and go through the steps to figure it out. I used to buy rounds from cheaper than dirt with my dpms and never had problems with the federal though:eek:
  17. Nov 22, 2012 at 2:37 PM
    ffemt2987
    Austin
    Golden
    Look to see if the round is being pulled to the left against the inside of the upper receiver when this happens.
    It should be pulled toward the ejection port as soon as it clears the chamber "obviously I know.."
  18. Nov 22, 2012 at 2:40 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Sounds like it's not even ejecting manually... the bullet weight wouldn't have an impact on that, and he's using Federal and Hornady, so it's not cheap steel casings getting stuck.
    OP, is the bolt extracting the casing from the chamber and just not ejecting it, or is it simply sliding back and jamming the next round into the chambered casing?
  19. Nov 22, 2012 at 2:40 PM
    ffemt2987
    Austin
    Golden
    I think his issue is beyond round quality since it won't eject a live round when trying to clear it.
    With your DPDS can you put the bolt it backwards? You know how most have a notch showing the correct side. I have heard they don't.
  20. Nov 22, 2012 at 2:52 PM
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Yes it extracts it from the chamber but will not eject it at all...first 40 rounds shot flawless then all of a Sudden this shit
