New gun FTE
Discussion in 'Guns & Hunting' started by mash25, Nov 22, 2012.
  1. Nov 22, 2012 at 3:30 PM
    #41
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    4: roll pin
    5: ejector spring
    6: ejector
    There are other long springs, but given the circumstances I'd say that's more than likely the ejector spring.
  2. Nov 22, 2012 at 3:34 PM
    #42
    mash25
    mash25 [OP] Roll Tide Roll
    Mark
    Bama
    '08 DC Sport 4X4..
    TGC 3'' lift,18'' Addicts,33'' Trail Grapplers
    No i didn't take the roll pin out the spring just fell out when I pull everything out...and sorry I don't have the correct terminology just pissed my brand new gun fell apart
  3. Nov 22, 2012 at 3:37 PM
    #43
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I don't care, just trying to help you out, it's easier to diagnose the problem when everyones on the same page. So is the ejector present or not?
  4. Nov 22, 2012 at 3:37 PM
    #44
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    I think you are right. Wasn't doubting you... not a part you can get to without serious dissassembly. I was thinking of what you could get to without a punch
  5. Nov 22, 2012 at 3:38 PM
    #45
    ffemt2987
    Austin
    Golden
    I was the one using the wrong term. I was hatin' on myself. I feel your pain. But, it is a manufacturers issue at this point and they could easily just send you a new bolt.
  6. Nov 22, 2012 at 3:39 PM
    #46
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    No ejector isn't present neither is roll pin that's supposed to hold it in
  7. Nov 22, 2012 at 3:40 PM
    #47
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Just trying to help keep everything straight. Easy to get all the parts confused when you're new to this stuff so posted some pics. Not trying to be a douche haha. Was all for OPs benefits.
  8. Nov 22, 2012 at 3:45 PM
    #48
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Well I'll try to get a hold of dpms to resolve this since I'm guessing it isn't a simple fix
  9. Nov 22, 2012 at 3:45 PM
    #49
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Bummer... so at this point you could contact DPMS and they may have you return the bolt or the whole gun or they may just send you something... I have no idea how DPMS's service works. Or del-ton and others sell the parts for like 10$. You could try that and see, but you may be right, it may be something more. Improper machining maybe. I can only think the ejector roll pin and ejector launching themselves could be improper clearances/machining or improper installation. Of course collateral damage is something I'd be worried about as well, where did those pieces go and what did they run into or what ran into them before they flew out of the gun, or are they hiding somewhere still? Of course if you had your new ejector assy and everything worked fine then you're probably alright. Just things to consider.
    If nothing else go to BCM and get a sweet ass bolt for 70$.
  10. Nov 22, 2012 at 3:46 PM
    #50
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's your problem then.
    The roll pin worked it's way out, and the spring launched the ejector.
  11. Nov 22, 2012 at 3:46 PM
    #51
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    So I can't fix this myself? I mean I know it's under warranty and all just curious
  12. Nov 22, 2012 at 3:50 PM
    #52
    Rich91710
    Rich
    Los Angeles
    08 Base
    Depending on the cause.
    If the bolt was drilled oversize, then a replacement rollpin will work it's way out again.
    You can try... it's just a simple matter of inserting the spring, the ejector plunger, holding the plunger flush with the bolt face (fair amount of pressure), and pressing the roll pin back in to retain the ejector.
  13. Nov 22, 2012 at 3:53 PM
    #53
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    If you had a small enough ball gauge and a mic you could figure that out easy enough I guess.
    That's what I was wondering, why did it come out? Tolerances or installation error?
    Possible to stake the roll pin?
  14. Nov 22, 2012 at 3:54 PM
    #54
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Most likely not with out spending some money. Like what the guy above said you could go get a BCM bolt and it would be a lot better quality than DPMS. You've now seen first ha d the quality of DPMS so my suggestion would be to upgrade rather than replace with more sub par parts.
    Besides even if you do drop the extra $70 you still have a complete rifle for under $700..
  15. Nov 22, 2012 at 3:56 PM
    #55
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You could try... But you say you are new to the AR world right? IMO, just send it in for warranty work. If there's any discrepancies with the rifle, it's the manufacture's fault and not yours.
  16. Nov 22, 2012 at 4:03 PM
    #56
    Rich91710
    Rich
    Los Angeles
    08 Base
    Agreed.
    While I'm no BCM fanboi, their bolt assemblies are top-notch. I also really like Daniel Defense.
    Get DPMS to warranty this one, then keep it in the "Spare parts for SHTF" box and install a quality BCG.
  17. Nov 22, 2012 at 4:17 PM
    #57
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Can I buy just the BCM Bolt assembly instead of the whole carrier? And put it in my dpms carrier?
  18. Nov 22, 2012 at 4:38 PM
    #58
    Rich91710
    Rich
    Los Angeles
    08 Base
  19. Nov 22, 2012 at 5:19 PM
    #59
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Ay good suggestions on here's here I could find one
  20. Nov 22, 2012 at 5:39 PM
    #60
    Rich91710
    Rich
    Los Angeles
    08 Base
