New gun FTE
Discussion in 'Guns & Hunting' started by mash25, Nov 22, 2012.
  1. Nov 24, 2012 at 11:55 AM
    #81
    mash25
    mash25 [OP] Roll Tide Roll
    Mark
    Bama
    '08 DC Sport 4X4..
    TGC 3'' lift,18'' Addicts,33'' Trail Grapplers
    Very well put...thank you Wiley
  2. Nov 24, 2012 at 12:13 PM
    #82
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    DPMS is a mil-spec gun. You can get an aftermarket "better" bolt that should solve the problem.
    Agreed that some of us are "brand" snobs, and some people say it better than others. This is a public forum and everyone is entitled there opinion. Keep that in mind when bashing the posters for theirs.
    There is a reason we are brand snobs, some of us have been in situations where if your weapon fails....so do you, not all but some of us. Just sayin.
  3. Nov 24, 2012 at 12:44 PM
    #83
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    And it works. :cheers:
    I didn't read through the whole thread but if you do as suggested before and upgrade your extractor, spring and install a black O ring from bravo company your gun should run fine for your needs. Good luck man
  4. Nov 24, 2012 at 2:57 PM
    #84
    TrdSurgie
    TrdSurgie revised
    Oahu
    :spy:
  5. Nov 24, 2012 at 3:06 PM
    #85
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    well... it's his ejector that's the problem
    is the hole for the roll pin oversized? did they install it wrong? IDK
    best plan is contact DPMS and get a new bolt then go from there
  6. Nov 25, 2012 at 8:13 AM
    #86
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Ejector =extractor
    same thing...
  7. Nov 25, 2012 at 12:20 PM
    #87
    RevAdam
    RevAdam Impressive Member
    Adam
    Upstate SC
    11 TRD OR 4x4
    Icom 5100 radio, Baja Rack, Kenwood 6980, ARB Bull Bar, Lightforce HID lights, Warn winch, LED lights, 5100s, Switchbacks, Redarc TowPro
    Sorry.. but that is inaccurate.
    The ejector is the little pin that actually pushes the cartridge out of the rifle. The extractor is the hook that pulls the cartridge out of the chamber...
  8. Nov 25, 2012 at 3:43 PM
    #88
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Nope.
    Extractor is the clip on the side of the bolt that grabs the rim of the casing and pulls it out of the chamber.
    The Ejector is the pin that pops out of the bolt face when the bolt reaches the back of it's travel and kicks the casing out the port.
  9. Nov 25, 2012 at 8:09 PM
    #89
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Oops. Thanks for the correction :)
  10. Nov 25, 2012 at 11:46 PM
    #90
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Noob :rolleyes: :p :D
  11. Nov 25, 2012 at 11:52 PM
    #91
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    the thing that gets me, is why is there a protrusion ontop of the extractor?
    Its obviously not a 8th lug, since it doesnt mate with a corresponding barrel lug.
    The extractor would probably work better without the fake lug on the back side of it too.
  12. Nov 26, 2012 at 12:14 AM
    #92
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    stiffen the machined part?
  13. Nov 26, 2012 at 5:43 AM
    #93
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    lol I totally forgot about that little pin :eek:
  14. Nov 26, 2012 at 7:29 PM
    #94
    Rich91710
    Rich
    Los Angeles
    08 Base
    Likely.
    There's a fair amount of stress on that lip.
  15. Nov 26, 2012 at 8:00 PM
    #95
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ...my guess is it is what contacts the dust cover, ...flipping it open when you pull the bolt (charging handle back)...
  16. Nov 26, 2012 at 8:51 PM
    #96
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's the "dent" in the side of the carrier where the gas vent holes are.
    Chamber a dummy and look in the center of the port.
    The carrier has a "divot".
    Close the dust cover. Pull the charging handle back 1/2" and the port pops open.
  17. Nov 26, 2012 at 8:58 PM
    #97
    wileyC
    Centerville, OH
    ah, i see said the blind man :D... that's what i get for being too lazy to go look for myself... can't remember if i read or heard this somewhere (history channel maybe?) but that recess on the carrier may have a dual purpose, ...as a "natural" forward assist of sorts, as eugene stoner had originally intended...
  18. Nov 26, 2012 at 9:04 PM
    #98
    Rich91710
    Rich
    Los Angeles
    08 Base
    It would be easy enough to say that if you need the FA, then you need to rechamber, but there is one practical purpose for the FA, both for hunting and combat, is that it does allow you to quietly chamber the first round, or to ensure being fully chambered after a press check.
  19. Nov 27, 2012 at 4:36 PM
    #99
    wileyC
    Centerville, OH
    yes, more so for the latter... from what i understand stoner didn't like the idea of a fwd assist spur, ...it was the military that wanted it on there... otherwise the recess in the bolt carrier could serve as the means to assure the bolt is in battery by pressing it toward the chamber using a thumb or index finger...
  20. Dec 8, 2012 at 5:48 PM
    #100
    mash25
    Mark
    Bama
    '08 DC Sport 4X4..
    Update to original post...the issue has been resolved and my gun is back slinging ammo down range...dpms sent me a complete rebuild kit and I rebuilt the bolt and now she's good as new...and I also ordered a spare bolt just in case...thanks for everyones help with the problem I had...:cheers:
