New gun ideas
Discussion in 'Guns & Hunting' started by taco084gb, Jan 29, 2009.
  1. Jan 29, 2009 at 9:47 PM
    taco084gb
    taco084gb [OP] No matter where you go there you are.
    Galen
    NorCal
  2. Jan 29, 2009 at 9:50 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    sweet the 700 is always a good choice. Last I heard the newer models were using timy trigger groups in them.
  3. Jan 29, 2009 at 9:56 PM
    taco084gb
    Galen
    NorCal
    So what are these timy triggers that you mentioned not sure what they are? Havent spent a whole bunch of readin into the remington but the T/C was what I was first lookin at then A friend mentioned the Remington now I like it too. To many choices and not enough BLING.
  4. Jan 30, 2009 at 12:34 AM
    ERdept
    ERdept Well-Known Member
    The Remmy has more aftermarket and more barrel options and can be made to shoot extremely well.
  5. Jan 30, 2009 at 4:02 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Don't you mean T/C has more options?
    I have had a number of T/C's all of them impressive. I am working on one now with a custom .308 barrel. With so many barrel options even wildcats, and stock set up's the sky is the limit.
    I have not been a fan of the newer Remingtons just like Winchesters, to many things have changed unless you want to drop a pretty penny.
    Check out everything then make the call, to check on some T/C stuff, look up E. Authur Brown.
  6. Jan 30, 2009 at 11:08 AM
    taco084gb
    Galen
    NorCal
    Hey longbow what type of 308 are you building. That is the caliber that Im lookin at as well. The T/C in the Pro hunter with Flex tech stock and the 308 heavy barrel in 28" SS is the one that I like.
  7. Jan 30, 2009 at 11:57 AM
    longbow
    Bill
    Indiana
    I am not to impressed with the Flex Tec stock, Bell and Carlson makes a better one in my book.
    I have the Encore receiver in full camo, did a trigger job and added new springs. The barrel is a med/heavy taper, bead blasted S.S. Not a bench gun, but still a little heavy to swing in the woods.
    Had them cut the chamber to make it a tight .308, since I will be reploading for it, I will have control over case length.
    All's you really need is the receiver then you build it the way you like, I tried the thumbhole stock, since I have one on my Knight. Didn't like it, the T/C stocks are good but need more meat. B&C stocks are close to the same price, a little more weight but for me the feel is better.
    I am still working on a base for the scope, can't make up my mind and don't want to add a cheap Alum. one. Leupold and Burris are good choices, but a little to much metal sticking up. I am looking into a guy to cut me some bar stock and make my own base. But still need to work up the specs.
    It is a gun system that all's you need to do is switch out a barrel and you are good to go on what ever you want to shoot. I have a couple of other shops that deal with Encore's and custom work. I need to find them but will post them later.
  8. Jan 30, 2009 at 12:01 PM
    taco084gb
    Galen
    NorCal
    Thanx 4 the info.
    I am favoring the T/C as well but just liked the looks of the Remmy. I have owned a T/C b4 but was the lighter frame in the 223 in a pistol. Sold it though:(
  9. Jan 30, 2009 at 2:57 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Im guessing hes talking about Timmeny Triggers. If so I would be surprised if Remington is putting these trigger groups in their 700's. They are very, very nice aftermarket trigger groups.
  10. Jan 30, 2009 at 3:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes they are! I have one on my AR. A sweet crisp 3# single stage pull, with NO creep, and 1/8" reset. :D
  11. Jan 31, 2009 at 1:37 PM
    taco084gb
    Galen
    NorCal
    Now the remmy that Im lookin at has an adjustable trigger from1-1/2# to 3-1/2# so this should be good right but not sure how this is comparing to the Timmeny triggers though.
    Also the length of the barrel is 20" does this make a difference as to the 22" or the 26" barrell with the same twist which is 1 in 12".
  12. Jan 31, 2009 at 1:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the rem. 700 is a sweet shooter...........but go with the t/c man!!!
  13. Jan 31, 2009 at 1:42 PM
    taco084gb
    Galen
    NorCal
    So what are your thoughts on the T/C over the Remmy tacoman?
  14. Jan 31, 2009 at 1:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well.......i have always liked remington shotguns and rifles, but it seems to me that out of the box.....gotta do too much work to get the newer rifles to shoot good/accurate. with the t/c's,out of the box, they already shoot great, and they they are built fantastically. as a matter of fact, and im a cva black powder guy myself............i am looking at a t/c contender or omega inline for this upcoming season. i haver shot them before.........and they are nice!
  15. Jan 31, 2009 at 1:50 PM
    taco084gb
    Galen
    NorCal
    Thanx 4 the info:)
    Should be gettin my new P220 Sig in another week. They said it was about 6 weeks out cause of backorder. I got the 2 tone silver slide with Signite sites. Cant wait:D
  16. Jan 31, 2009 at 3:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    O gotta say, go with the 700. Much more accurate out of the box than the TC. Most of the Remmy's that have needed work are the less expensive models. The 700 is a bench mark rifle.
  17. Jan 31, 2009 at 6:21 PM
    ZonKs
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    The general rule is the longer the barrel the greater the velocity you (or the bullet, actually) will achieve.
  18. Jan 31, 2009 at 6:24 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
  19. Jan 31, 2009 at 6:25 PM
    ZonKs
    Ted
    Glendale, CA
    2018 Sport DCSB 4x4
    =p
    Gotta agree there. I love mine (700 VS LH). Cant stop pimpin' it. :eek:
  20. Feb 2, 2009 at 3:30 PM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    A while back I picked up a Rem 700 in the VTR version in 223. It cost a lot less than th XTR, and is a light weight, compact, accurate rifle. While it does not have the fancy trigger, the one that came on the gun was very decent and I've shot some good groups with the gun using el cheapo PMC 55gr FMJ ammo and plan to do some experimenting with some heavier moly-coated bullet reloads. The twist is 1-9, so ought to be quick enough to stabilize bullets up to roughly 75 grainers, and might even work with 80s. We'll soon see.....
