New guy going out of my mind picking tire size.
Discussion in 'Wheels & Tires' started by muggsy, Mar 27, 2013.
  1. Mar 27, 2013 at 5:53 AM
    muggsy
    muggsy [OP] Member
    NEW YORK
    07 TACOMA TRD 4x4
    Bilstein Adjustable 5100S Front. 5100s Rear
    Alright i have a 2007 trd access cab, bilstien 5100s front and back coming friday. Was going to buy tires and rims , now going tires only on stock 16" rims. I did a temporary black plastic dip paint job with a red pin stripe on it and think it looked real good. Now im going to sand blast and have them powder coated. what is the biggest A/T tire i can stuff under there. I have been reading posts for a week on this and keep getting different sizes? Even the tire people are giving different answers. I will post before and after pictures when i figure out how. Thanks.
  2. Mar 27, 2013 at 6:03 AM
    Large
    Large Red
    Generally, 265/75/16. You are getting mixed answers because it's kind of debatable on what the largest size you can fit. Without any more info (like what type of tire do you want, do you plan on keeping the stocks? If you swap to aftermarkets you will probably rub, what are the 5100s set at?) it's hard to give an accurate answer.
  3. Mar 27, 2013 at 6:41 AM
    muggsy
    muggsy [OP] Member
    NEW YORK
    07 TACOMA TRD 4x4
    BFG a/t or nitto TG. Bilstiens on order, probably going to set at what truck looks like level, so could be max.
  4. Mar 27, 2013 at 6:54 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Have you had the TSB performed on the rear leafs or have an AAL?
  5. Mar 28, 2013 at 3:15 AM
    muggsy
    muggsy [OP] Member
    NEW YORK
    07 TACOMA TRD 4x4
    No TSB OR AAL. Never new about the TSB at the time, if i have to AAL its no big deal to me. What would be the best AAL to buy?
  6. Mar 28, 2013 at 3:42 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    Silver 2010 DCSB 6-speed supercharged
    You can get a 2" AAL from toytec for pretty cheap. If you get the 5100s on I would think max (2.5 setting) would give a pretty stiff ride, considering all the preload on the springs.
    Your profile also doesnt state if you are prerunner or 4x4. If you are 4wd you need to consider your CV angles. A 2" add a leaf and the 5100s set at .85 or 1.75 are a pretty common combo. 265/75/16s are a good size tire too. You could probably stuff 285s under there with a good bit of trimming or if you like the look of the tall skinny like I do, a 255/85/16. Probably less to trim with those.
  7. Mar 28, 2013 at 3:46 AM
    OldGeezer42
    OldGeezer42 Well-Known Member
    Adam
    Louisiana
    07 DCLB Silver Base
    Husky mats,30% tint all around, DTRL,OEM Bed mat,UWS Tool box,OEM fog lights,5100's,Wheelers 3leaf HD springs.OEM cruise control,OEM wipers,,Avid light bar,Flyzeye Leds,4x4 illuminated switch.Matt123 skids,bed lights,Ome 884s
    I did the 5100's in front and back, and the 3 Leaf HD 1.5 AAL from Wheelers. I put P265/75/16 Hankooks ATMs , they don't rub,and they are some good looking tires, cheaper than others.
  8. Mar 28, 2013 at 3:48 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2012 Lifted Tacoma Doublecab (SOLD)
    4" zone offroad suspension lift modified with Rcd bilstein front shocks w 1/2 spacer for 5.75" front lift and allpro expo leap pack with 2" block for 6" rear lift, extended length stainless brake lines front and rear, beefed taco carrier bearing drop brkt, 1.25 alum driveshaft spacer, avid lightbar powdercoated w 2 9" led lights, , amp research power steps, anderson aluminum drop hitch, ss grill insert w color matched grill, color matched door handles, color matched rear bumper, color matched pop n lock tailgate handle, 2012 sport mirrors added, color matched mustang hood scoop, borla ss exhaust, extang full tilt tonneau cover, windows tinted darker,oem roof rack, 2014 touch screen radio w navigation, infinity kappa speakers front and rear, rockford fosgate amp, 2 10" kicker subs, 2tone katzkin leather, hydro dipped interior parts, inalfa 925 power moonroof, lexus F sport shift knob
    get the 3 leaf add a leaf pack if you do so will give you a better ride
  9. Mar 28, 2013 at 5:38 AM
    muggsy
    muggsy [OP] Member
    NEW YORK
    07 TACOMA TRD 4x4
    Thanks, I'm going to stick with the 265/75/16 Sand blasted stock rims yesterday, going to take then to be powder coated today,do i buy the BFGS or the General A/T2, not happy with both being a E rated tire. Mostly pavement driving with snow and sand now and then. Had many sets of 35" BFGS on bigger pickups with no complaints, but i think they look to sidewall aggressive in a smaller tire then the General? Have to pull trigger real soon.
  10. Mar 28, 2013 at 5:58 AM
    BORNWILDGUY
    Rich
    Florida
    Look at the toyo at II or cooper at III Both available in c rated and both come with a treadwear warranty
    www.treaddepot.com
