New guy question bout my yota
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Markaspden, Aug 5, 2016.
  1. Aug 5, 2016 at 5:39 PM
    Markaspden
    Markaspden [OP] New Member
    Hi, I have just purchased my first Tacoma 2008 double cab with off road package.
    I have a couple of questions
    1 How does the 110 out let work in bed of truck, a plug my compressor in and turn it on. It will run for a few seconds then it shuts off and I have push the switch is this normal or am I doing something wrong.
    2 I have no power to my 2 12 volt outlets I have replaced the big fuse in fuse box you know the one that took a hour I had to remove battery, fuse box still nothing, is there another fuse somewhere any help please.
  2. Aug 5, 2016 at 5:45 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The bed receptacle is rated at, I believe 100 and 400 watts depending on which you set it to. If you exceed that it probably shuts it down.
    There are a couple different fuse boxes. Theres one in the cab behind the coin tray above your left knee. Then 2 in the engine bay. Both beside each other, near where you described teplacing fuses.
