New guy with 2010 SR5 Access; tire question
Discussion in 'Wheels & Tires' started by Carlo, Feb 12, 2010.
  1. Feb 12, 2010 at 11:51 AM
    Carlo
    Carlo [OP] Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    I have been reading some info here and done some searches about 265/75/17 tires. I want to run these bigger tires and do very little off road driving. The turck has the stock 245 on it now, and I am fairly happy with the ride. What do I need to do to run these bigger tires/wheels (currently have 16'' stock weels). I went to 4weeelparts and I did not know that I wanted 265's; I only told him bigger tires generically. The guy there said he can do a daystar 2.5'' and 5100's. After leaving, I wonder if he thought I wanted to run 285's. So, what do you all suggest to run the 265/75/17 given it's a daily driver and at most a light trail/ fire road truck?
  2. Feb 12, 2010 at 12:48 PM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    So are you getting different rims or what?
    you say 265/75/17s, but yet you have 16" stock wheels.
    Stock trd Off Road wheels are 16" with 265/70/16 tires
    Stock trd Sport wheels are 17" with 265/65/17 tires
    no lift with 16" rims biggeset size tire- 265/75/16
    no lift with 17" rims biggest size tire -265/70/17
    (these larger than TRD size tires look ok with a 3"lift or smaller)
    these size tires require no lift, but also look fine with leveling kit or 3 inch lift.
    so you can safely move up one size tire with no problems and no lift.
    Most people on here that have 3" lift suspension choose 285's,
    USe the search, find similar threads, read on....
  3. Feb 12, 2010 at 12:52 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Welcome to TW! 1st set your budget for how much you want to spend. You'll also need to decide how much "work" you want to put into running bigger tires. On a non lifted truck 265/75/16 fills out the wheel well nicely. If you lift it 2.5" with billy 5100s and aal on the rear, 285s look much better, but keep in mind you'll probably either have to run wheel spacers on stock wheels or get aftermarket rims with at least 4.5" backspacing to allow for proper clearance.
  4. Feb 12, 2010 at 1:00 PM
    Carlo
    CA
    Thanks for giving some info; I guess it's a commonly asked question. Thanks, Carlo
  5. Feb 12, 2010 at 1:13 PM
    Outlaw
    Iowa City, Iowa
    Oh and Welcome to TW!
    I forgot that you were a noob so sorry if i sounded harsh, didnt mean to.
    There are tons of guys on here from California.
    Check the buy/sell/ trade section on this site for rims and tires, before you jump into buying a new set up.
    lots of rims and tire swaps happening here...
  6. Feb 12, 2010 at 2:20 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Go with the 265/75R16 if you going to keep you original rims.
  7. Feb 12, 2010 at 4:24 PM
    Carlo
    CA
    I will check out the used stuff; I did not realize that there was one here. Learning lots. BTW, took a drive in my new truck today. Great day for a ride. I know I want at least one bigger size than stock, I am trying to figure if I want to get new wheels or not. If I do 265/75/16 will they fit without any back space issues? Thanks again for all the help.
  8. Feb 12, 2010 at 5:00 PM
    skistoy
    Western New York
    265/75R16 on stock steel rims, no rubbing at all, no spacers
