New Guy with Bilstein Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Reddrum, Sep 24, 2017.
  1. Sep 24, 2017 at 5:49 AM
    Reddrum
    Reddrum [OP] Well-Known Member
    Charleston, SC
    Perfect...thanks jsinnard...I'll def get that bushing replaced .....any chance the dealer has or can order these coilovers to install for me when I'm ready to buy the truck?
  2. Sep 24, 2017 at 5:50 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
  3. Sep 24, 2017 at 5:55 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    You'd probably have to buy the coil over from a 3rd party and provide for the dealer to install. They probably won't warranty the parts but should warranty the instalkation. This should be discussed and ironed out prior to the sale and every dealership is different.
    You might even drive the truck stock for a few months first just to ensure everything is in perfect working order before you modify the truck. Don't worry, the Toyota aftermarket won't disappear anytime soon.
    djthicks likes this.
  4. Sep 24, 2017 at 5:55 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    It's definitely possible, depends on how cool your Toyota dealership is but chances are you'd get overcharged versus ordering from a supplier online.
  5. Sep 24, 2017 at 5:58 AM
    Reddrum
    Charleston, SC
    ok...thanks guys.....So yesterday, dealer here says they can do a lift kit up to 3" that'll maintain factory warranty etc...I'm assuming he's referring to a Toytech kit....and he quoted $1200 ....which is pretty close to all four Fox coilovers plus the bushing replacement.....is maintenance of the Toytech kit more trouble than what it's worth?
    stevotivo12 likes this.
  6. Sep 24, 2017 at 5:58 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Keep in mind you're getting charged for a complete truck so if you swap shocks or wheels and tires before delivery, make sure to get the takeoff parts too.
    You can recoup some of the cost by reselling the stock parts.
  7. Sep 24, 2017 at 5:59 AM
    stevotivo12
    Stephen
    Nothing wrong on that end, just no longer the ride quality you were searching for @Reddrum
  8. Sep 24, 2017 at 6:03 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Agreed, you'll get the height and it will be done but willing to bet it will be a spacer and block lift. Ask for specifics on which lift they would install, maybe even see if they already have a lifted truck on the lot to see and take a drive in.
  9. Sep 24, 2017 at 6:04 AM
    Reddrum
    Charleston, SC
    jsinnard...yep, definitely...I'm selling tires and wheels as well.... stevotivo12...so Toytech kit reduces ride quality vs the coilovers.....really good to know.
  10. Sep 24, 2017 at 6:05 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Depends on which Toytec kit, they sell both spacers and coilovers, spacers reduced ride quality.
  11. Sep 24, 2017 at 6:06 AM
    Reddrum
    Charleston, SC
    Was really hoping they could get the coilovers thrown into my financing :)
  12. Sep 24, 2017 at 6:09 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
  13. Sep 24, 2017 at 6:11 AM
    Reddrum
    Charleston, SC
    Good idea...I've read these are pretty decent as well.
  14. Sep 24, 2017 at 6:13 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    But if they're not locked into toytec, ask about @stevotivo12'S suggestion as well.
  15. Sep 27, 2017 at 8:44 AM
    #35
    Reddrum
    Charleston, SC
    Any problem with just installing the new front coil overs and leaving the rear factory Bilsteins in place?
  16. Sep 27, 2017 at 8:57 AM
    #36
    stevotivo12
    Stephen
    Not a problem per se... ride quality might not be the best since you would have two completely different struts with different dampening curves and all that. Its best to have a single set of shocks if you can rather than two different pairs
  17. Sep 28, 2017 at 6:08 PM
    #37
    Reddrum
    Charleston, SC
    The TRD OR comes with 5100's, correct? Which are adjustable? Seems I saw 5100's listed in spec sheet...
  18. Sep 28, 2017 at 6:36 PM
    #38
    eurowner
    eurowner Duke Sky
    Scoty
    Yellow HDs, not silver 5100s came stock on my 2017
  19. Sep 28, 2017 at 7:24 PM
    #39
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    If your goal is ride quality, your tire choice may also be a factor. The E-rated K-bros are known to ride rough. If you are want the bro-look, without the bro-ride, you should make sure you stick with P or C load rated tires.
  20. Sep 29, 2017 at 5:30 AM
    #40
    stevotivo12
    Stephen
    Yeah the code is 4600 I believe, but those are non-adjustable
