New Guy with Tacoma Issues
Discussion in 'New Members' started by mtxcdude, May 21, 2020.
  1. May 21, 2020 at 2:49 PM
    mtxcdude
    mtxcdude [OP] New Member
    1999 Tacoma Base model
    Just joined up with Tacoma World. I'm based in a small town in South Western Montana. I've got two 1999 base model Tacoma's. Both are 4wd, 5 speed Manual, 2.7 liter engines. One is running strong with 255k miles. The other has 296k miles with issues, which is why I joined up. I do most of my own maintenance and need to pick some brains on how to get 296k back on the road, if possible, or maybe just part it out.
    The dang thing will not start. It turns over but I've not got it to start since last November. I've got spark to every cylinder and can smell gas when I try to start and when I pull the plugs. Either is not starting it. I replaced the fuel filter, no go. I swapped the EFI fuses. 255k still runs, 296 still no go. Compression test was disappointing, low and uneven compression. #1 145, #2 125, #3 125, #4 80. I took the compression after pouring a little Marvel Mystery Oil in each cylinder. Any ideas out there in Tacoma World. Thanks
    Bigdaddy4760 likes this.
  2. May 21, 2020 at 3:20 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
    Have you checked valve clearance?
  3. May 21, 2020 at 3:24 PM
    Zersko
    Zersko Well-Known Member
    Northeast
    2016 Tacoma SR5
    Welcome to TW!
  4. May 21, 2020 at 3:52 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    tcjacado likes this.
  5. May 21, 2020 at 5:23 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  6. May 22, 2020 at 10:27 AM
    mtxcdude
    I've never adjusted valve clearance on either Tacoma. I watched a couple you tube videos and am going to attempt it. Looks pretty easy on the vids.
    I'll purchase the recommended tools to depress and hold the bucket in place to access shims. The whole process actually looks interesting. I'll be able to check out the timing chain and guide as well as other stuff.
    Thanks for the welcome replies!
    Don
  7. May 23, 2020 at 2:04 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
