New hardware for LCA’s or reuse old?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hcnelthropp, Jul 30, 2021.
  1. Jul 30, 2021 at 10:32 AM
    Hcnelthropp
    Hcnelthropp [OP] Member
    2010 pyrite mica trd OR 4x4
    Just got a fresh set of lower arms for 2010 dblcab 4x4 OR. Should I use the original bolts or buy new?
  2. Jul 30, 2021 at 10:33 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Originals are fine. They are cam bolts. Kind of pricey to replace for no reason. But if you bought new lcas I'm guessing the bushings are seized and you may need to cut them out and forced to replace them.
    Geeves77 likes this.
  3. Jul 30, 2021 at 10:34 AM
    Hcnelthropp
    Thats what I was told. Thanks.
  4. Jul 30, 2021 at 10:52 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    I bought new hardware but really didn’t need it. You won’t know till you start so best to have them on hand.
    SR-71A likes this.
  5. Jul 30, 2021 at 10:58 AM
    JayRolla
    Colorado Springs
    I used these on my 3rd gen 4runner. They have a plastic sleeve so no metal on metal contact like oems. They will never seize up.
  6. Jul 30, 2021 at 11:59 AM
    Eastkat808
    Eastkat808 Well-Known Member
    Esket
    2012 DCLB 4x4 sr5
    bilstein 5100 cranked up
    If the sleeve is seized in the bushing you could try getting a m12 (possibly m10) Allen head bolt, just enough so the threaded part fits into the sleeve but the head of the bolt seats flush with the sleeve, make sure the bolt head is about the same size as the sleeve so you can punch the bolt all the way through the bushing with the sleeve. Then get a tapered punch on a air hammer and just go to town MC HAMMER TIME on that sucker. The reason you would want to use a Allen head instead of a regular bolt is because the Allen head gives the punch something to stay in place. If you were to use a regular bolt you’d have to reset your pounding position each time.
    It should come flying out so wear some safety goggles. You can clean it up with a wire wheel and reuse everything. If for any reason you or any of your buddies don’t have access to a air hammer I’m sure with a little elbow grease this can be done with a BFH.
    I did this method when replacing my LCAs because I didn’t want to spend the extra money to either buy new ones from Toyota or aftermarket ones. Mine were still good just stuck a little bit.
    Hopefully this helps or give you an idea instead of taking a saw to your truck and spending more money
  7. Jul 30, 2021 at 12:06 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    They are like 45 bucks. If they arent rusted to shit, id reuse them. If not, its not like you won't be able to buy groceries if you get new bolts.
