New Hawaii Safety Check Law
Discussion in 'Hawaii' started by TRDGRL, Sep 24, 2013.
  1. Sep 29, 2013 at 2:20 PM
    808DAKINE
    808DAKINE Well-Known Member
    Kai
    Lahaina, Hawai'i
    01 Taco
    Cold air, Sounds, lift, lights, exhaust and a canoe!
    Wait so HiD is illegal? I just did a retrofit on my 01. Does that mean i need to revert them to get my safety done?.. and does Maui have recon? Why is there so little information on this.. or can I just not find it.
  2. Sep 30, 2013 at 2:53 AM
    808DAKINE
    Kai
    Lahaina, Hawai'i
    01 Taco
    Yea i get what you say. I seen some sky high, like one toddler can run under easy. Put my spare back on and my bumper stay 29 inch lol. oh well, according to what I have found, my truck passes recon no problem except the lights. I dont know why they wouldn't though... bmws and caddys all have hid projector bi-xenon lights..
  3. Sep 30, 2013 at 8:07 AM
    pringles808
    pringles808 Well-Known Member
    Honolulu
    2012 SW PreRunner
    OME 885x, Bilstein 5100 f/r with driver lean spacer, toytec 2" aal, D2S Morimoto 5000k HID Retrofit, BHLM, Switchbacks, Roll N Lock
    just a update on the safety check issue. Starting October 1st is when the new safety check system will be implemented. It will be a one peice sticker design and so far, only 5 locations on oahu will be doing them starting tmrw
    kahala shell
    lex brodie queen street
    toyota veh. proc. center
    bradley serv. center
    dollar rent a car
  4. Oct 3, 2013 at 3:16 AM
    Ste
    Ste Well-Known Member
    Oahu, HI
    05 4x4 Access cab V6
    3inch block lift
    do i need a safety check before i register my vehicle to HI from CA or it doesnt matter?
  5. Oct 3, 2013 at 4:12 AM
    Kala
    Kala Well-Known Member
    BigIsland
    05 PreRunner SR5
    Stock truck...go to safety check station, get blue copy, go to dmv, getplates, go to safety check station and get finalized.
    Now if you need recon, make an appointment, try get a temp safety, but get the recon and have the blue copy of safety and go dmv, then go back to safety check station.
  6. Oct 7, 2013 at 8:46 PM
    808DAKINE
    Kai
    Lahaina, Hawai'i
    01 Taco
    Any news about Maui?
  7. Oct 8, 2013 at 3:24 AM
    808DAKINE
    Kai
    Lahaina, Hawai'i
    01 Taco
    What they look for? Last time I took my truck to get safety checked, it was stock lol
  8. Oct 8, 2013 at 12:35 PM
    Ste
    Oahu, HI
    3inch block lift
    Can anyone recommend a place in Waikiki for recon and alignments check?
  9. Oct 8, 2013 at 9:45 PM
    StaticTaco
    StaticTaco 2 is 1, 1 is none.
    Mitch
    Oahu
    2011 SR5 4WD
    I recommend Scotty's in Aiea, they are fast and if you get there early (730, they open at 8) they usually take you in and your out by 8. awesome staff (of 2 haha) but yeah, top notch work, they also give a alignment print out if you need to take it to recon.
  10. Oct 8, 2013 at 9:47 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    Just a question on safety checks, anyone know if its legal to have your exhaust pipe dump right after the rear axel? I sawed off my muffler tip but the pipe is still pointing down and away from the cab, you just can't see it unless you look under. thanks for any info.
  11. Oct 8, 2013 at 9:48 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    If its not loud, I don't think anyone will care
  12. Oct 8, 2013 at 9:53 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    ok cool, thanks, its not loud at all, I think it's a flowmaster 50 delta flow, I can't remember. but it really only gets loud at the higher rpms.
  13. Oct 8, 2013 at 11:18 PM
    Ste
    Oahu, HI
    3inch block lift
    cool thanks, how much do they charge and recommend a good recon station? need to get mine done asap before the 30 days after transporting
  14. Oct 8, 2013 at 11:29 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    last time I went for alignment it was around 65 to 70 bucks, this was for a stock alignment. don't know if that's a good price, but yea, they do good work.
    as for recon station, jboy671 got it right, there's only one station and its by appointment only. it's in Kaimuki under the overpass.
    here's intel about it,
    http://www.tacomaworld.com/forum/hawaii/99156-hawaii-recon-information-q-thread.html
  15. Oct 9, 2013 at 2:04 AM
    #35
    Ste
    Oahu, HI
    3inch block lift
    oh gotcha, was hoping for more... my appointment is booked about 3 weeks from now... >.< might have to pay a late fee.
  16. Oct 9, 2013 at 1:42 PM
    #36
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    bro be aware they may not pass you because of the notch some say gotta be wleded to pass some say no can at all
    i went in before i notched passed then cut it up
    just a heads up bro hopefully they dont really notice just be on time be friendly and talk story it helps alot make sure all your lights are legal, tint, and have your alignment sheet cause they will check everythiung should pass i just would be worried about the notch sometimes they let it pass sometimes they dont they change their rules and reasons alll the time
    i dont think should be a problem everyone says no can gotta exit but on my slammed 2000 sierra i had i took em good year with recon dumped exhaust before the axle and they failed me for 2 small sticker on my windshield in the corners never said anything else was wrong
  17. Oct 11, 2013 at 2:07 PM
    #37
    Kala
    BigIsland
    05 PreRunner SR5
    For safety checks, the exhaust must exit after the passenger cabin. As long as the tip goes past the cab it's good to go. SUVs were arguable, since we would consider the most rear window as the end to the passenger cabin, we discouraged people from chopping and dumping directly after the muffler on suvs.
    Also, this can be used against you if pulled over or vehicle impounded and thoroughly inspected. Safety check laws and the hawaii revised statues that the law enforcement officers go by are two different things. §291-22 Regulation of exhaust pipe and muffler. It shall be unlawful for any person to drive upon the public highways any motor scooter, as defined in section 286-2, the exhaust pipe or muffler of which has been so changed from the factory design as to increase the volume or audibility of the explosions within the motor thereof.
  18. Oct 13, 2013 at 1:10 PM
    #38
    Ste
    Oahu, HI
    3inch block lift
    if my tires slightly rub will i fail the safety check or recon ?
  19. Oct 13, 2013 at 5:26 PM
    #39
    CBoy808
    CBoy808 Sticker Making Dude
    Tacoma Mall Crawler
    you could potentially fail both. what part is rubbing, minor trimming can fix quite a few rubs. especially if its just slightly...
    i have 275/70/18's on my truck which is stock height, I had to trim a little bit of the fender flare and remove the front mud flaps, no more rubbing except over big bumps.
  20. Oct 13, 2013 at 7:44 PM
    #40
    Ste
    Oahu, HI
    3inch block lift
    gotcha thanks, any pics of your trim by any chance?
