New Headers! And new issues - Not starting ('97 3RZ)
Discussion in '1st Gen. Tacomas (1995-2004)' started by 12ozcurls, May 18, 2015.
  1. May 18, 2015 at 5:20 PM
    12ozcurls
    12ozcurls [OP] Active Member
    Dylan
    Monterey Bay, CA
    96 Tacoma 4x4 3RZ-FE
    ToyTec 3" coilovers, 3" OME Dakar leaf springs, Light Racing UCA, LC Engineering Long-tube headers, Deck-plate mod, K&N rock and stick filter, SiriusLED headlights.
    Alright, so what started out as a day-long project of installing my new LCE headers after finding out my exhaust manifold was cracked, has turned into a nightmare.
    I got the headers installed last night, and when it came time to fire up my Taco; much disappointment ensued. It won't start. It cranks, but will not start. I pulled out my #1 spark plug and there's gas on it, so I know it's getting fuel, but when I tested the ignition, I'm not getting spark in any cylinder. I've checked all the grounds that I can see, thinking I may have bumped one when installing the new headers, but everything looks fine.
    I'm really hoping that it's just user error and I just missed something. But any help would be appreciated to get this thing back on the road.
    (EDIT) Sorry, it's a 96, not a 97.
  2. May 18, 2015 at 5:25 PM
    12ozcurls
    Dylan
    Monterey Bay, CA
    Other things I've checked:
    Rotor still spins, contacts are not burned (Cap and rotor were replaced less than 20k miles ago).
    Plugs look fine and have less than 5k miles on them.
    Cleaned MAF sensor
    Every 5th/6th time I try to crank the motor over, it sounds like one MAYBE two cylinders fire, but still will not start.
  3. May 18, 2015 at 7:30 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Unplug everything you touched and messed around with,then redo it. Which shouldn't really be anything but your MAF senor and couple senors for the airbox.
  4. May 19, 2015 at 12:54 PM
    12ozcurls
    Dylan
    Monterey Bay, CA
    Alright, so I've tried unplugging and reinstalling those cables and resetting the ECU. Nothing seems to be working. Getting it towed. I'll update when I find out what the problem is.
  5. May 26, 2015 at 8:57 PM
    SR5Tac0
    SR5Tac0 Well-Known Member
    Los Angeles
    98 SR5 V6 4x4
    Did you ever find out what the problem was?
  6. Jun 4, 2015 at 3:32 PM
    12ozcurls
    Dylan
    Monterey Bay, CA
    UPDATE! Sorry to anyone who was waiting to find out what the cause of my problem came from. The mechanic that fixed my truck told me it was my ECT sensor. That was replaced and it didn't cost me nearly as much as I thought it would've been. Gas mileage seems to have improved and the throttle seems to be slightly more responsive (though I'm not sure whether to attribute that to my headers or the sensor).
    I have my truck back and it's running like the champ I know she is! Next up is wheels, wheel studs, lower ball-joints, hubs and tires! I may also do my drums too while I'm down there.
