New headlight and fog light bulbs.
Discussion in 'Lighting' started by MGH-PA, Jan 13, 2012.
  1. Jan 13, 2012 at 3:19 PM
    MGH-PA
    MGH-PA [OP] Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    Yes, it's a newb question, searched a little and found many of you have mixed feelings about the Silverstars (all I can get locally), so what do you recommend? I just noticed my drivers side low beam and passenger side fog is out (weird that they both happened at the same time), so I need to get in there ASAP. No interest in HIDs since I want to keep the housings and everything stock, but I figure, while I'm replacing, if I can get something better than stock, why not? Going to have to go online for them, so if you have recommendations for a retailer, that would be great, too. Thanks!
  2. Jan 13, 2012 at 3:38 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I like PIAA Xtreme White for the headlights and Nokya Arctic Yellow for the fogs. I got both at Amazon.
  3. Jan 13, 2012 at 3:42 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I had sylvania silverstars in my headlights before my retros and they were really good. Quite a bit brighter then stock so I liked them. I only had them on for a little over a year so I'm not really sure how good their longevity is.
  4. Jan 14, 2012 at 5:06 AM
    Snoranger
    Snoranger Well-Known Member
    SW Washington
    Silver 2012 TX Pro
    Philips LED Headlights PIAA Xtreme White Fogs Block Heater 30% Tint Decals Removed
    I have PIAA Intense White in my headlights, and Xtreme White Plus in the fogs. I've always had good luck w/PIAA for longevity, esp compared to Sylvania.
  5. Jan 14, 2012 at 5:28 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    i would recommend going with something like this, i listened to pugga when he recommended it to me, but got the intense white headlights instead. either one will work quite well, but i really dont thing i have ever run across a fog light bulb that i liked better than the nokya's without having to go HID or upgrade a harness or something like that (no simple replacement bulb). i ran the sylvania in every car i owned since prob the early 2000's when they first came out. good choice if you dont know what else is out there, but once you find out they really cant hold a candle to what else is out there esp with the deals you can find on Amazon. so i would say PIAA's for headlights and def nokya's for fogs.
  6. Jan 14, 2012 at 5:28 AM
    Motorjock 721
    Motorjock 721 Well-Known Member
    Wylie Texas
    2018 TRD Sport double cab 2wd inferno
    None yet
    Been thinking about changing my bulbs out. Anyone know what Part number i need?
    PIAA Intense white bulb for the headlights---
    PIAA Xtreme white plus bulb for the fogs---
    Thanks
  7. Jan 14, 2012 at 5:31 AM
    toka670
    toka670 Well-Known Member
    ft bragg
    2010 Rock Warrior
    aftermarket headlights 6000K HID 6000K fog lights smoked LED tail lights
    6000k HID are nice! :D
  8. Jan 14, 2012 at 5:34 AM
    toka670
    ft bragg
    2010 Rock Warrior
    you don't need to change your housings to install HIDs. just plug n play and they are still all stock!
  9. Jan 14, 2012 at 5:49 AM
    Pugga
    Massachusetts
    I don't know the bulb part number but here are the bulb types. If you search Amazon for PIAA Xtreme White H10 and PIAA Intense White H4, you'll find both of them or check PIAA's website for part numbers (I couldn't find the Xtreme White for the fogs).
    http://www.tacomaworld.com/forum/lighting/84308-lighting-faq-please-read-before-posting.html
    High & low beam headlamp
    9003/HB2/H4
    Fog/Driving light
    9145/H10
  10. Jan 14, 2012 at 5:52 AM
    Pugga
    Massachusetts
    But if you're going to throw HIDs into a stock housing, you shouldn't keep it stock, you should retrofit projectors into the housing. Stock housings are not meant to have HID bulbs in them.
  11. Jan 14, 2012 at 7:11 AM
    toka670
    ft bragg
    2010 Rock Warrior
    thanks did not know bout that.
