New Headlights for 2010
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PMK, Dec 12, 2019.
  1. Dec 12, 2019 at 3:46 AM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Bought my truck the last day of 2009. So in a few weeks it will be 10 years old.
    So far, i have had warranty replacement of the original headlights, a second set of headlights, and now, again the clear outer shells are showing cracks.
    Seems doubtful they will warranty the headlights again.
    So, I am considering aftermarket headlights. Again these are on a 2010 DCLB Prerunner and came with the tinted headlights.
    Did searches here but found no good answers.
    Was toying with going LED if possible.
    So other than buying oem, what are some high quality options that are LED or if not LED simply retain the halogen setup.
  2. Dec 12, 2019 at 3:56 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Pics???? I have the stock TRD sport black housing headlights and they seem to be doing fine. Try DEPO brand aftermarket possibly???
  3. Dec 12, 2019 at 4:05 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    If you go to and search the Lighting forum, you'll find more than a few posts on this subject. The consensus is that for best optics and performance, OEM is still the way to fly. Yes, there's a ton of aftermarket stuff available for less money, but it just not going to perform as well and it certainly won't last even as long as your OEM lights.
    If you want the absolute ultimate in performance out of your OEM (or even aftermarket) halogen headlights, skip the LED junk and consider this:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    Since your biggest problem appears to be the outer lens oxidizing, I would recommend a good synthetic sealant or ceramic coating. Believe it or not, it will significantly extend the life of the units.
    ace96 and crashnburn80 like this.
  4. Dec 12, 2019 at 5:44 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Three sets of headlights in less than 10 years is not very good in my opinion.
    No plans to truly improve light performance as in that topic. Besides, after seeing the heat increase, it would have me think longevity of the lens will be even less.
    Oxidation vs crazing cracks. My lens have very little if any oxidation. Yes some is there but not an issue. The true concern is the lens on both headlights and both taillights have hundreds of small crazing cracks in the plastic material. Not burned or melted, simply the plastic is deteriorating and failing.
    If I do find a replacement headlight assembly, was under the impression that projector style headlights with high output LEDs would match or be better than oem halogen.
    To simplify my original question, what replacement headlights, besides oem are people here buying.
  5. Dec 12, 2019 at 5:57 AM
    Too Stroked
    Tom
    Interesting on the cracking and not oxidation.
    Good luck on any aftermarket headlight housings though. They just don't have the design, engineering or manufacturing skills of the OEMs - which explains the lower prices.
    As far as projector style headlights, HID's will out perform LEDs any day of the week. And yes, a good projector system will out-perform the OEM halogen style. Again beware, because there are a ton of crap Chinese HIDs (as well as LEDs) out there.
  6. Dec 12, 2019 at 6:10 AM
    PMK
    Florida
    10 DCLB TRD Sport
    No doubt, and exactly why I am asking what others have purchased and had good luck with on their early style 2nd gen replacement headlights.
    USMC176 likes this.
  7. Dec 12, 2019 at 6:21 AM
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    MtnMan307 likes this.
  8. Dec 12, 2019 at 6:23 AM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    He's worried about the condition of the plastic, not the light output.
  9. Dec 12, 2019 at 6:26 AM
    cvisinho
    Rhode Island
    its not that much of a price difference though to have best of both worlds.
    Ive never had a crak in my Depo lights and they have been on with a retro kit for almost 4 yrs now.
  10. Dec 12, 2019 at 7:06 AM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
  11. Dec 12, 2019 at 12:22 PM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    That would be my vote as well. I had that exact same setup, Depo headlights with the Mini H1 projectors, on my last Tacoma. I’m going to do my current 2010 soon with the black Depo headlights again but the D2S projectors.
  12. Dec 12, 2019 at 12:52 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    My 2010 is 2 days older than yours. :)
    This past spring while it was in the shop for body work, I asked if they repaired headlight lens covers. They charged me $110 to remove headlights, 600 grit sand, 1000 grit sand, clear coat, then bake in the oven, and reinstall. They are crystal clear and look new. Yes the plastic is probably a few microns thinner but it's a 10 year old truck that looks nearly new.
    Marc70 likes this.
  13. Dec 12, 2019 at 8:31 PM
    PMK
    Florida
    10 DCLB TRD Sport
    If mine were just coated with oxide build up, that plan would work great. Sadly mine have crazing cracks in the plastic lens.
  14. Aug 19, 2023 at 7:26 AM
    tlavergne
    tlavergne Member
    Thomas
    2010 TRD Tacoma
    I am replacing my headlights with TYC as linked in post #10. There appear not to be any beam adjusters on the back (see pics in Amazon link). Can anyone shed some light on how to adjust these? I have these on hand ready to install but don't want to install until I figure this out. Thanks...
  15. Aug 19, 2023 at 7:33 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Should look similar to this. Don’t adjust the horizontal, only the vertical.
    [​IMG][​IMG]
  16. Aug 19, 2023 at 9:50 AM
    tlavergne
    tlavergne Member
    Thomas
    2010 TRD Tacoma
    Perfect. Thank you very much.
    crashnburn80 likes this.
