New headlights....
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomainthesun, Dec 21, 2018.
  1. Dec 21, 2018 at 3:05 PM
    tacomainthesun
    tacomainthesun [OP] Well-Known Member
    2002 Taco DCSB Lunar mist 4x4 TRD OR
    It has come to my attention that they are a bit dim. What should I get as a replacement? It’s just the bulb, not the housing that I should probably replace. It’s not fogged up or anything
  2. Dec 21, 2018 at 3:21 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Search around there are a TON of threads on this subject, but most of them roll back around to this one:
    https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
    The rest depends on your budget. There are some pretty cool ways to get a lot of extra light using some brighter OSRAM bulbs, but because they burn brighter, they don't last as long. To get a little extra brightness, you can do the "ultimate upgrade" which includes using an upgraded wiring harness that gets voltage directly from the battery with thicker wires, so even if you don't change your bulbs, the light does get brighter (more volts supplied).
    See here:
    https://www.tacomaworld.com/threads/proper-headlight-upgrade.407879/
    I've been running some Sylvanias and they do fine. But I also have brand new (they were brand new 2 years ago, that is...) CAPA certified housings from RockAuto, and the upgraded wire harness. I'm very happy with it.
    If you still need any more light, and you'll be venturing into the "not DOT legal" territory (actually the proper upgrade isn't technically legal, either). At that point, get some LED lightbars for the roof or bumper and only use them off-road...
  3. Dec 21, 2018 at 3:24 PM
    tacomainthesun
    When you ask a couple questions and get a wealth of information you know you’re on TW. Thanks, I’ll check it out and post any questions :thumbsup: I don’t think I need to get into a “not DOT legal” amount of brightness o_O
  4. Dec 21, 2018 at 3:25 PM
    rnish
    rnish Well-Known Member
    Maryland USA
    Tacoma 2nd gen
    Pro Suspension (Bilstein), OME Dakar (med), armor
    I left my headlights halogen. Changed my fogs to LED’s, they fill in without blinding oncoming traffic.
  5. Dec 21, 2018 at 3:26 PM
    tacomainthesun
    I don’t even have spots for fog lights
  6. Dec 21, 2018 at 3:41 PM
    jbrandt
    Sacramento, CA
    There are a lot of cool things you can do for that. If you modify your corner marker lights to house the turn signals, too, you can replace the old turn signals with LED fogs. You usually have to do a bit of fabricating to mount them, but the results are pretty cool.
    I did the turn signal mod, but because I was removing my lower bumper valance for off-road clearance.
    Here, you can see that I drilled holes in the corner lights. Then cut off the bulb mounts from the turn signals and epoxied them in place.
  7. Dec 21, 2018 at 3:51 PM
    tacomainthesun
    Very tempting but I don’t have the “know how” to do fabrications. :( So basically I just need to make sure I get halogen bulbs?
  8. Dec 21, 2018 at 4:04 PM
    rnish
    Maryland USA
    Tacoma 2nd gen
    I'm using Hella HB2's halogens for headlights. They are brighter than stock and last a few years. Sylvania makes some very bright white/blue bulbs but they didn't last a year. Not sure what bulb a 1st gen uses.
    HELLA H83300072 HB2 9003 H4 12V 60/55W High Performance 2.0 Bulb
    by HELLA
  9. Dec 22, 2018 at 5:23 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
  10. Dec 22, 2018 at 6:20 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I like my truck appearance to be pretty much stock, so these cheap little jewels were enough for me. I could easily drive on local roads at night without my headlamps, even though it's only like an additional 40Ws of light. I have them angled for "low beam" working height and separately switched. <$20.00 Amazon/China of course.
  11. Dec 22, 2018 at 7:31 AM
    tacomainthesun
    Looks good. I have at the locking rear differential so I can justify the lighbars I guess. Mod potential just keeps growing:spending:
  12. Dec 22, 2018 at 7:38 AM
    tacomainthesun
  13. Dec 22, 2018 at 9:13 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    96 Tacoma Xtra Cab 2.7L
    Toytec Bilstein 5100's, Chevy Leafs.
    When it comes to vehicle lights I'm quite the minimalist. I don't care for the halos and RGB LEDs they have gone crazy with these days. It's a personal choice and some people like them but I don't. People like to Peacock with their truck though so I understand that.
    RysiuM likes this.
  14. Dec 22, 2018 at 11:00 AM
    tacomainthesun
    Taco>investments
