new help wiring exterior HID light
Discussion in 'Lighting' started by 03tacoman, Feb 3, 2013.
  1. Feb 3, 2013 at 11:20 AM
    03tacoman
    03tacoman [OP] Well-Known Member
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    I am doing blackdawg's free blinker relocation mod. which will leave my lower light housings empty and i want to put 35w 3k HIDs into these empty housings. I need to know how I am going to get power to them without messing them up. I'm going to have a switch in the cab so that I can have them on/off whenever I want.
    Since all I am going to have is this kit
    http://www.ebay.com/itm/140756939258?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    I need to know how to power it since I won't have a wire with a plug on the end of it that I just simply plug the HID kit into...
    1. do I cut the connector off of the HIDs and just crimp the + and - to my wires that I run ?
    2. can I use 18g wire?
    3. What power source should I take power from? the battery? a fuse tap on the horn fuse inside the cab? orrrrr ? I'm confused as hell need some help!
  2. Feb 6, 2013 at 10:43 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
  3. Feb 10, 2013 at 2:51 PM
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    What does the relay do exactly? why can't you just wire it straight from battery to fuse to lights? thanks!
  4. Feb 12, 2013 at 5:38 PM
    bellassaiw10
    Currituck NC
    Regulates the electricity ? im not exactly sure lol but the relay box obviously does something its supposed to, I would direct wire because then you could over power them and catch your truck on fire
  5. Feb 13, 2013 at 6:43 AM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    A relay is basically a switch...
    I'd advise against running a wire directly from your battery to a switch in your cab.
    It is much safer to have a 2.5 AMP 18 AWG relay trigger wire running through your firewall; than having your lights on a direct on/off circuit to your in-cab switch.
    Please, do yourself a favor and do some research on 12 volt circuits before going through with this mod. This topic seems to come up about once a day in one form or another on here...
    Do a quick search.
  6. Feb 14, 2013 at 6:03 AM
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    So the relay trigger wire would just be a smaller wire going to my switch that turns the relay on which then puts power to the lights? I will look that up thank you! just hard sometimes to know exactly what I need to research. thanks
  7. Feb 14, 2013 at 11:44 AM
    bellassaiw10
    Currituck NC
    Why not just order the relay and wire the H4 end to the old turning signal wires
  8. Feb 14, 2013 at 3:26 PM
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    because I need my turn signal wires?
