New Help With Purchasing the Right Rims
Discussion in 'Wheels & Tires' started by JohanVC, Jun 10, 2020.
  1. Jun 10, 2020 at 8:06 AM
    JohanVC
    JohanVC [OP] New Member
    2008 Tacoma TRD Off-Road
    Hello everyone!
    I'm hoping that someone can lend me some aid. So I have a 2008 Tacoma and I want to be able to put 285/75r17 (or 16inches not sure yet) tires on it. I'm in the midst of purchasing rims, but I just want to make sure I buy the right ones. I'm looking at the American Racing Baja's. If I purchase W20271 size:16x8 PCD6x139.7 Offset 0 Bore 108will they fit?
    Any advice or help that I can get would be greatly appreciated! If you have a similar set up please share some photos.
    Thanks!
  2. Jun 10, 2020 at 9:36 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    The wheels will fit. The tires won’t work unless ypur lifted and plan on trimming some stuff. The tire size you mentioned is approx. 34” tall. You’ll will also want to get some hub bore rings to fill the gap at the hub since the recommended hub bore is 106.1. Also depending on wheel design sometimes they may rub the calipers if you go with a 16”.
  3. Jun 10, 2020 at 11:32 AM
    JohanVC
    Awesome! Thanks for the help. Yep, I installed a three-inch leveling kit in it. So, should I go for a 17-inch rim?
  4. Jun 10, 2020 at 11:57 AM
    gotoman1969
    Usually more sizes to choose from for tires in a 17. To run the 285/75/17 you are gonna need UCAs. Trim some fender and do a cmc.
  5. Jun 10, 2020 at 12:34 PM
    JohanVC
    Gotcha. I do have JBA offroad control arms installed, but what is a cmc?
  6. Jun 10, 2020 at 12:50 PM
    gotoman1969
    Cab mount chop.
