New here check out my ride!
Discussion in 'New Members' started by TacomaTwins2, Jul 29, 2011.
  1. Aug 5, 2011 at 1:21 AM
    #41
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    Nice x man but what size are they turbos? 29 lbs is a lot for stock heads... suprised they can hold it but I don't think anyone has blown the heads on these yet.... also what are you running fuel pump wise? you said you added another one...I'm guessing you had another one added inline with the current one? where did you get your injectors from?
  2. Aug 5, 2011 at 1:24 AM
    #42
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Damn, that thing looks great! I'll bet its a blast to drive...wish mine had alot of go fast MODs lol
  3. Aug 8, 2011 at 8:32 AM
    #43
    TacomaTwins2
    TacomaTwins2 [OP] Member
    Christian
    Miami
    Twin Turbo Xrunner-(REDRUM)
    Fully Custom Twin Turbo setup by PSI Racing.JDM Suspension and Rotora Brakes.
    My injectors were purchased from TD aurowerks in Miami. I was running 1 inline Weldon 600 series Pro comp capable up to 700hp.Then added another WELDON 600 so now each bank will have its own feed and pump to work with the new 1600cc injectors I installed.
  4. Aug 8, 2011 at 1:02 PM
    #44
    xroller
    X-roller
    1 hp mod
    what fuel rails are you running? Turbo size?? lol.
  5. Aug 9, 2011 at 12:15 PM
    #45
    TacomaTwins2
    Christian
    Miami
    My turbos are Turbonetics T3/T4 57/59 non ball bearing turbos also my fuel rails are custom made and the stock intake bottom part was modified to use 1000cc injectors. Also as far as the heads go they are bone stock! And have had 1 problem with them I broke 1 intake cam ,replaced it and it is running again,I have xtra heads and will be porting and ordering springs & cams soon.:cool:
    zerotimeouts likes this.
  6. Aug 9, 2011 at 9:43 PM
    #46
    xroller
    X-roller
    1 hp mod
    Wow nice set up bro. I'm guessing the same company made your fuel rails? The one that made the intake? Sweet set up but still don't understand how you had a 111 trap speed at 650 to the wheels?....
  7. Aug 10, 2011 at 12:27 PM
    #47
    TacomaTwins2
    Christian
    Miami
    Yea 2Jz would have been cheaper but more common and if that was the case I would have built a Supra...;)
  8. Aug 11, 2011 at 1:22 PM
    #48
    xroller
    X-roller
    1 hp mod
    Exactly. Be different. Nice choice man. :thumbsup:
  9. Aug 16, 2011 at 10:11 AM
    #49
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Looking at the engine bay pics, it looks like your fuel rail is either -8AN or -10AN, but kind of hard to tell. Which one is it, but very nice?
    Are you planning on running a surge tank your fueling, or keeping it as is with the current large inline?
    I am running Injector Dynamics 1000cc injectors right now. What brand are you using that made you have to customize the lower intake manifold to make them work?
    I also noticed on your dyno graph that your rpms went to about 6500. Since your heads are stock, are you planning on upgrading the valve springs? I would highly recommend that if you hadn't thought about it.
    Good job on the Caltracs. Keep that wheel hop at bay.
  10. Aug 17, 2011 at 6:19 AM
    #50
    TacomaTwins2
    Christian
    Miami
    Thanks! Def. have to work on traction and will probably be looking into smaller wheels with street slicks for the track once I retune it....Yes i went with the -8AN fuel lines & Fuel Rails,I was using Precision 1000cc now using Bosch 1600's with the Precisions the bottom part of the injector is thicker than on the Bosch so I had to drill out the holes on the botton manifold to accomidate and spacers for the fuel rails.For now leaving the fuel setup as is down the road maybe getting like a large fuel cell perhaps.
    For now just have to keep the tank more at least half full to race..
    As for the heads..I have the rev limmiter set for 6,800rpm but try to shift at 6500 or so..I am about to begin building new heads that I have off a spare motor and will be replacing the valve springs,porting&cams..its going to be a while until I put them together and even install them,for now one step at a time,I want to see how it runs on the E85 as is...Hopefully in about 2 weeks I may have results from tuning and will post them,thanks
  11. Oct 12, 2011 at 10:32 AM
    #51
    TacomaTwins2
    Christian
    Miami
    Just retuned check out this link!
    http://forums.haltech.com/viewtopic.php?f=3&t=9105
  12. Oct 12, 2011 at 10:35 AM
    #52
    xroller
    X-roller
    1 hp mod
    top notch man. keep it up!
  13. Aug 24, 2013 at 12:44 PM
    #53
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I felt like this needed a bump
  14. Aug 25, 2013 at 1:18 AM
    #54
    HonoluluTaco
    HonoluluTaco Well-Known Member
    Koi
    Reston Virginia
    10 TRD 4x4 OffRoad DC/SB
    2010 TRD OffRoad DC/SB, 285/70/17 KM2's, Mickey Thompson Classic Locks, Total Chaos UCA's King 2.5 RR Coilover 3" AllPro Leaf Pack, 2.0 Fox RR, Ubolt flip kit, MBRP dual cat back, URD TCAI and MAF Calibrator, TRD Sport Hood w/ scoop, E&G Classics Custom Stainless Grill, Color matched grill and door handles WeatherTech floor mats, FormulaOne Pinacle 15%+Air blue windshield Tint, RedLine hood struts, TRD 3rd Brake light Decal, Relentless Fab Hybrid 2 piece Sliders with Kick out Relentless Fab Aluminum Front bumper, Relentless steel rear bumper, Relentless Steel IFS B.A.M.F LCA Skids, w/ Rear Diff Skid ordered In my Spare room waiting to be installed sits, Wet Okoles, Illuminated 4x4 switch mod, SockMonkey Hawaii TRD OffRoad Decal, Big box of Rammat, Speakers and Custom Sub from Mr.Marv,
    Sick truck, Aloha and Welcome
  15. Aug 25, 2013 at 2:10 AM
    #55
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
  16. Aug 27, 2013 at 12:11 PM
    #56
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Welcome
    Pretty engine
