new here Noob here
Discussion in '1st Gen. Tacomas (1995-2004)' started by rob1208lv, Feb 8, 2011.
  1. Feb 8, 2011 at 11:47 AM
    rob1208lv
    rob1208lv [OP] Well-Known Member
    Rob
    Las Vegas
    02 PreRunner V6
    I just inherited my Mom's Tacoma.
    It is very sentimental to me, and need a little work.
    Has about 90k miles came from a cold snowy area I live in a hot desert
    Not sure of any maintenance done so what should I do?
    Things I have done already:
    changed the oil to Mobil 1 10w 30 (5qt per manual) with a mobil 1 filter
    Changed the air filter (auto zone brand)
    changed some dead fuses
    Disconnected the tail gate light for the hitch (had a short and keep blowing the tail lights)
    Had it completely detailed by a detail shop.
    Note: while changing the oil I spilled a half quart all over the motor (been a long time since I've done my own work) I cleaned it as much as I could, will this cause any damage?
    What else should I consider doing ? Any recalls I should know about?
    The brakes do a weird jolt right before I come to a complete stop, however the brakes look fine. Does my truck have abs? because the abs fuse is completely missing?
    also there is a little water coming out the tail pipe could it be because it came from a snowy area? or a head gasket cracked head etc?
    Lastly I noticed a little crack-age in the belts. (that's on my weekend list)
    Thanks
  2. Feb 8, 2011 at 11:52 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    that "weird jolt" could be a leaking axle seal. i had my rear driver's side seal go on me a month and a half ago. it felt like the brakes would grab right before i came to a stop. really annoying.
    there's a frame recall on first-gen tacomas. you'll want to get that checked out. if yours fails the inspection you'll be qualified for a frame replacement. do a search -- there are a ton of threads on the topic.
  3. Feb 8, 2011 at 11:56 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    ok I'll inspect the rear axle thanks
  4. Feb 8, 2011 at 11:56 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Welcome to TW from snowy Ma. A little water (condensation) out the tail pipe is normal.
  5. Feb 8, 2011 at 11:58 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    Very relieved thanks
  6. Feb 8, 2011 at 12:07 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    At 90k you might want to think about changing the timing belt and water pump
  7. Feb 8, 2011 at 12:10 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    like above said, consider changing timing belt. make sure all fluids are topped off, some oil spilled on the motor will do no damage, and water out of the tailpipe is normal for everyone( as said above)
  8. Feb 8, 2011 at 12:22 PM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    Ok my list so far is
    Timing belt, Water pump, other belts, check rear axle seals, top off fluids, did I miss anything?
  9. Feb 8, 2011 at 2:34 PM
    97yota4wd
    Eric
    Mesa, AZ
    i think you should be good to mod after that:)
    edit:add long travel to the list.. haha
  10. Feb 8, 2011 at 2:41 PM
    codybarger
    codybarger Active Member
    cody
    breckenridge
    02 trd
    my truck did the same thing with the jolt... axle seal was bad. i changed the wheel bearing and everything when i did mine because you have to take it all apart to get to the seal... if it is a bad seal check the shoes and drums because mine were caked in grease. if the case you will need to change also. once the grease seeps in there done. good luck. also its not a easy job i had to torch out my wheel bearing.
  11. Feb 8, 2011 at 3:39 PM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    Do the rear diff breather mod to help avoid blowing rear seals.
  12. Feb 8, 2011 at 3:42 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    Congrats on the new Tacoma, and welcome to TW. Hope everything works out for you. Even if this was to somehow become a money pit, I full well understand sentimental reasons to keep a vehicle!
    I personally changed all my fluids when I bought my Tacoma (although it had 180k miles). I just figured for the price, I might as well make sure everything was new and good. I did a coolant flush and diff. fluid replacement in addition to the fluids mentioned already. Also, its PROBABLY a given, but have your battery tested. The last thing you want is it failing on you. Are the tires still good?
    Then, there's Seafoam. Some people consider it snake oil -- I liked it personally. Do a quick search and you'll get more information than you could possibly ask for.
    Schedule a frame inspection asap.
  13. Feb 8, 2011 at 4:14 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    there is a couple recalls you could have done. there is the lower ball joint recall and also the anti rust proofing frame spray since it spend its life in a snowy region the frame spray may be a good idea up to you though. oh and dont worry about the spilled oil thats just added undercoating. another thing you could do is change out the fuel filter if you havent already. i hope i could help.
  14. Feb 8, 2011 at 4:23 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    also some more fluids that are due for changing if you havent already are your transmission fluid and rear diff.
  15. Feb 8, 2011 at 8:22 PM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    It's going to take me a year to do all this .. lol
    Thanks everyone
